Reception from tv breaking up with deafening hissing from the earphones
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
Sharp 26" tube tv, getting a hiss all the time. not a reception issue, is the tv. Is there an issue with the speakers ?
Does it still happen while the volume is down too? and do you have a cable box/satellite receiver connected to it as the main volume controller?
Sep 27, 2010 | Sharp Televison & Video
Sound comes only in one earphone..
your headphones probably blew in the one ear. Try another pair of headphones.the same thing happened to me. if that doesnt work the recepters in the ear jack youll have to have a professional to fix it
Feb 28, 2010 | Philips Audio Players & Recorders
Will it work in Spain
HELLO
Your TV must be switchable from PAL I (UK) to PAL B/G. If your set cannot be changed over from one transmission standard to another, then you will NOT pick up any transmissions.
Though if you want to you can use it via scart/AV connections to satellite box of some type and that will get around the problem.
ALL THE BEST (:-)
Nov 26, 2009 | Toshiba 24AF41 24" TV
A4 Cabrio (53) lost radio reception
Ensure you have power from the radio feeding the booster/pre amp.
Apr 14, 2017 | 2003 Audi A4 Cabriolet
Hissing sound
you can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Jul 12, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Digital tuner
if the signal breaks up and the picture looks like small squares with audio coming in and out its 99% of the time signal / reception how old is your ariel it may not be suitable for digital.
http://www.freeview.co.uk/help/reception-viewing/q2
Nov 17, 2007 | LG 42PB4D 42 in. Plasma HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
