Question about Sky Cell Phones
Does the sky phone home screen suppose to go out in 7 sec even if you have it set for five minutes?
I forgot my password to my new Galaxy Sky cell phone
Google how to do a hard reset Galaxy Sky and you will come up with Sites and even Video that will suggest something like this:
  1. Power off your cell phone.
  2. Next hold and press Volume Down + Power button.
  3. Then if you see Android man with triangle, then press Menu key.
  4. Now choose option "wipe data / factory reset" using Volume buttons to scroll, and Home button to confirm operation.'
  5. Only this time, write your pswd down.
Nov 19, 2017 | Samsung Cell Phones
I am using my nokia e52 . When i am trying to on my camera,my phones display was going white for 2-3 sec and i return to the home screen.
Mr. Naveen kumar!Switch off your hand-set and Please try by removing your SD card and see it happen again or not?
If it happen means your OS (operating system) may be corrupted.
Try this code *#7780# it's for restoring the setting in a soft way. (selecting 'settings only will reset all preference settings. Restoring will not delete any personal data. After restoring, the phone will restart)
where as *#7370# it's for hard way (lets you restore settings and delete personal data. You will not be able to use or switch off the phone during the restore, even for emergencies Restoring may take several minutes. After restoring, the phone will restart)
And if this is not working or helping you than refer to the nearest mobile service centre for FLASHING
Thanks for using FixYa.
Sep 27, 2012 | Cell Phones
Hello, please can you help me (and bear with me as I am somewhat technically challenged..) I have an HTC Snap S521 that has been working perfectly for the past 7 months.. suddenly my home screen has...
the start menu should still work to get to your settings if not and you bought the phone new 7 months ago take it back to the store phones have a waranty for 1 year and they have to fix it.
If you can't/don't want to take it back to the store you can hard reset it yourself (this will delete everything!)
Power off mode, press VOLUME UP and POWER BUTTON at the same time. The follow on-screen instructions to set everything back up again.
Mar 10, 2011 | HTC Cell Phones
My phone basically just started losing applications, when i went to text it isnt showing that i have any conversations, which i know i do, and when i hit the cross to add a conversation it freezes for a...
That shows the memory of your phone is full so try and decongest some information on your phone that you feel you don't need again to create space for you to be able to do some other things on your phone.
Feb 09, 2011 | HTC 7 Surround Cell Phone
N95 blank screen every 7 secs help?
kindly re upload your software!!!
Apr 25, 2009 | Nokia N95 Cellular Phone
Dash goes back to home screen from every application
Ah! sounds like your home screen is set for 10 secs. try going to settings, than to home screen. than scroll down to "time out"... you can set how long you want your phone to stay in an app. you can even set it to never and it will only close a program if you end it yourself.
hope this helps.
Jan 20, 2009 | T-Mobile Dash Smartphone
Screen Lock
From the front keypad go to the menu and there should be an option under settings and tools for the key guard, ther you will be able to change the settings either off or 7 secs or 15 secs I think.
Sep 09, 2008 | LG enV VX9900 Cellular Phone
My iphone 1.1.3 doesn't work
press power button and home button together. press them 2gether for 10 secs. this is soft reboot.
this shud reboot the iphone.
u may need to put ur network settings again.
Jul 24, 2008 | Apple iPhone Smartphone
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
Cell Phones Logo
Top Sky Cell Phones Experts
Andrew Taylor
Andrew Taylor
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a Sky Cell Phone Expert? Answer questions, earn points and help others
