Question about Tablets & eReaders
Galaxy tab 4 need to be rebooted it ws rooted and someone hard resetit
How can I reboot my Samsung galaxy 2 tablet 10inch. it keeps dropping pages or freezing when i'm playing a game . please help if you can ....Thank You ...
1.Make sure device is completely powered off. 2.Press and Hold The Power and volume down button at the same time. 4.Select factory data reset in recovery menu. 6.Reboot System Now and you're finished!18 Mar 2013
How to Hard Reset Samsung Galaxy Tab 2 10.1 Android 4.0 Remove ...
Dec 15, 2016 | Samsung Tablets & eReaders
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube
    • 3 MIN
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
    May 23, 2016 | Samsung Tablets & eReaders
    Hey i rooted my android tab and its never been the same its stuck on android 3.0.1 can this be fixed?
    Rooting a device always has the potential to turn the device into a 'brick' in some circumstances. Most good rooting procedures mention this, as well as steps to make a backup of the current system and how to recover from a failure to boot after rooting. There are also different 'mods' that can be tried to see if one of them will work in place of the one you first chose for rooting. These are all dependent on exactly how Android was modified for your hardware. Google 'rooting' and 'Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR' and see what the articles say. You can also try a hard reset of your tablet and see if that does anything. Example at this link
    Oct 31, 2014 | Samsung Galaxy Tab 101 Tablet...
    Forgot screen lock for Samsung galaxy 10.1
    A hard reset will do the trick.
    1. With the device off, press and hold Volume Up and Power.
    2. Release the Power button when you see the Samsung logo ( about 3 seconds), but continue to hold Volume Up until the recovery screen appears.
    3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Power to continue.
    The Galaxy Tab should then go through the hard reset process ( formatting user data).
    4. When formatting completed, navigate to select Reboot system and press Power.
    Feb 07, 2012 | Samsung Galaxy Tab 101 Tablet...
    Can you upgrade Samsung Galaxy Tab OS 2.2 to OS 2.3?
    Procedure to update Samsung Galaxy S with Gingerbread 2.3 version:
    Before we proceed to the updating process, please note that your phone needs to be rooted because your current file system must be converted to EXT4 which can be done with the help of latest version of Voodoo Lag fix. Also you need to backup all your data as there is a high probability that you may lose data after the updation. And also you must have Busybox in your device.
    • Now, you need to copy the file system-dump-as-root.tar.gz on the root of your SD card after which you will have to run these commands,
    adb shell
    cd /data
    mkdir gingerbread
    cd gingerbread
    busybox tar zxvf /sdcard/system-dump-as-root.tar.gz
    mkdir data
    busybox cp -a /efs efs
    reboot download
    • After this it is time to unzip to nonsgs.tar
    • Now, you will have to flash the kernel with ODIN client with NO PIT and NO Repartition selected. And this is it, Your Galaxy S will now run the Gingerbread 2.3 version. At any point of time if you wish to move back to the Froyo update then you just need to flash it again with the froyo ROM back by using the Odin but before that make sure that it must support the EXT4 file system or else your device may become unusable.
    Sep 22, 2011 | Samsung Galaxy Tab Tablet PC
    How to install a game on my samsung galaxy tab?
    Well, there is a place called "Android Market" or similar.
    If your desired game can be found there, simply download and install the game app and you can enjoy the fun.
    If the game can't be found, or it requires a fee to play. You'll probably need to root the device. Here is a 1-click Android-Root solution for your reference.
    Sep 07, 2011 | Samsung Galaxy Tab Tablet PC
    Galaxy p1000 is frozen cant switch off nothing is happening
    Hope this helps:
    How to Hard Reset Samsung GT-P1000 Galaxy TAB:
    If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
    If this does not solve the problem, perform a factory data reset. In Menu
    mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
    Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
    Feb 05, 2011 | Samsung Galaxy Tab Tablet PC
    Tablets & eReaders Logo
    50 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
