Question about Cooktops
Need to know how to wire for 115 and 230 volts or amp, to a jacuzzi, there are three wires, red, white and black to a fuse box. from a new pump? help!
    Sergeant:
  • 197 Answers
You should really get a professional to do that for you so that if anything goes wrong they are liable ..not you for any damages
Posted on May 05, 2017
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
I have a four wire on a 20 Amp service. I need 110 outlet.
4 wire recepticals are used for 220 Volt appliances, there should be 2 hot (117V to ground) and one each Grounding and grounded (read neutral) conductors) Breaker or disconnect should be 2 pole for 220 Volt circuit. A 20 Amp 110/117 Volt circuit would have a single pole breaker or disconnect, one "hot" conductor(should be black or colored , not green or white), one neutral conductor (should be white or neutral with white stripe) and an equipment grounding conductor (should be green or bare copper). It sounds to me like your receptical was wired for 220 V using whatever colored wires were handy. Back up to breaker or fuse (disconnect), and shut off circuit. New 117 Volt outlet will be wired with Black to Brass colored screw (short slot on face), One White wire will be used for Neutral conductor (make sure you know which one it is at the breaker panel) and one of the other white wires may (but shouldent be) used for ground (use green marker to identify it at each end),The third white wire should be removed if you can, otherwise cap with wire nut at each end and coil up in back of boxes. At the breaker/ fuse panel, the Black wire is connected to the breaker (It will be your "hot" lead), The white being used for the Neutral is connected to the neutral buss bar with the other Neutrals, and the green goes to the grounding buss bar (should have other green or bare copper wires. Once all is properly connected and secured but without the disposal plugged in, turn on the power and check for leaking smoke (smoke here is a bad thing) The fuse or breaker should protect your wires and help keep that smoke inside the boxes. Check voltages at the new plug, 117 V accross Short and longer slot, 117 from short to ground (round) and 0 or close to it from long (Neutral) to ground. If voltages check, plug in the new appliance and test.
If in doubt about what you have, dont hesitate to contact an electrician, they get paid for their knowledge and experiance and their ability to keep that nasty smoke inside the boxes.
Good Luck.,
Aug 14, 2009 | Jenn-Air JED8230 Electric Cooktop
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Burners not working but fan is
Are you sure that is the proper wire from the wall? What you are describing is a 110 volt circuit. THis cooktop should be connected with at least #10 wire and fused at 30 amps. You should have black red and at least white with possible bare ground wire. Assuming somebody used the wrong wire during original install job, you have it connected right. Please replace with heavier wire if it is not #10 Or at least make sure it is fused at no more than 20 amps if smaller wire. (You may sometimes blow circuit breaker if all burners are used on high at once) Use a volt meter and check voltage. If this is a 220 volt circuit you should have 220 volts between black and white and 110 volts from either one to bare ground wire.
Jul 02, 2008 | Jenn-Air JED8430 Electric Cooktop
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
69 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
