Question about Coffee Makers & Espresso Machines
Window showing "Ventilate" Cleaned regularly! How do I rectify?
3 Suggested Answers
  • 29 Answers
SOURCE: ventilate!....shows in window and machine
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Posted on Oct 24, 2010
  • 1089 Answers
SOURCE: IT SHOWS "VENTILATE" IN PRINCIPAL WINDOW. WHAT
Hi
That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water needed to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.bansheracer_15.jpgbansheracer_16.jpg
Posted on Jan 31, 2011
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Keeps showing ventilate. tried running the hot water. took removable machine parts out, cleaned, and put back. nothing works
Check the end of the steam wand, that could be blocked, if not then try this push in on the knob after you turn it open if that works, then replace the steam valve assembly.
Feb 25, 2010 | Gaggia Titanium Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
