Question about Kubota Garden
I have a kubota L355ss tractor the power steering went out can you tell me how to fix it
  • Kubota Master
  • 4,390 Answers
I am not familiar with the model. The steering is probably hydraulically assisted steering or power assisted steering rather than pure power steering. In the case of a pure power steering failure the tractor would be impossible to steer while a failure of power assistance means the vehicle steering is still connected to the wheels and it is possible to steer, if the driver's arms are strong enough.
Power steering is mostly reserved for larger industrial vehicles while almost everything these days is equipped with power assisted steering.
There are several ways a steering system can be given power assistance and there isn't space or time to discuss those here but regardless of the method, all except the very unlikely possibility of electrically assisted steering and the equally unlikelihood of compressed air assistance, will require a good supply of air-free hydraulic oil under high pressure, typically 500 - 1000 lb sq inch.
The first part of diagnosing the problem is to ensure there is an adequate supply of oil, that it is clean and there are no leaks and it is being delivered to the steering gear or ram with sufficient pressure and volume to provide the required power assistance. Once the visual checks have been carried out the safest method of checking further will be to use a hydraulic test rig.
It is most important during work on hydraulic systems that utmost cleanliness is observed to prevent dirt or water entering the system...
Posted on May 05, 2017
Troubleshoot lights on kubota m108sdsl
There is a fuse block under the steering column by your feet Check the fuses. There are also relay switches behind the dash you will have to remove your gages to get at them
May 16, 2015 | Kubota Garden
How many horsepower does a kubota tractor B8200 has / what year was it made
It was made between 1983 and 1990
Kubota B8200 Power:
Engine (gross): 19 hp [14.2 kW]
PTO (claimed): 16 hp [11.9 kW] (gear)
14.5 hp [10.8 kW] (hydro)
You can find more breathtaking information about this tractor at
http://www.tractordata.com/farm-tractors/001/2/7/1274-kubota-b8200.html
Apr 29, 2015 | Kubota Garden
Please can you tell me the year of a Kubota KX121-3SS excavator Serial number 30896 ?? Brian
here is a link for Kubota that may help you. It uses the engine serial # to tell you when the engine was built. It doesn't tell you when the engine was installed, though, but it should be very close to the same. http://www.kubotaengine.com/products/engines/engine-serial-number-identification>
Feb 21, 2015 | Kubota Garden
Kubota wont move
change fluid and filter on hydrostatic
Aug 27, 2014 | Kubota Garden
What year was kubota tractor serial #12863 made?
Contact cust. service at kubota.com Have model and serial no. They can tell you.
Mar 22, 2014 | Kubota Garden
Transmission oil leak at base of stirring wheel, above mowing deck where main transmission line comes and distributes to front transaxle cylinder and implement feed lines
Most small tractors have a power steering valve under the cowl through which the shaft to the steering wheel connects. The hoses may be leaking or loose fittings. My Kubota sends me under there about every 4 years.
Mar 18, 2014 | Garden
Kubota will not start again
The pushrod may not been in lifter.
Sep 17, 2012 | Kubota Garden
I need a down loadable manual for my kubota GL11000 diesal generator
Kubota GL11000 and Kubota GL7000 Manual http://www.pacifictoolcompany.com/index.php?main_page=index&cPath=13_127
Sep 30, 2011 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
I have a B1200 kubota tractor and want to get a manual on it
Call (803)-536-9411 or 800-849-9412 ask for Justin. Tell him Brad sent you
Pioneer Farm Equipment.
Brad.H
Nov 30, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
