Question about Samsung Microwave Ovens
My over the range Samsung Microwave fan comes on when I open the door.
  • Samsung Master
  • 9,098 Answers
You probably have a shorted relay on your control board. I regularly repair these for $54.95, which includes insured return shipping.
Contact me directly for more info.
- William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Posted on May 06, 2017
  • 473 Answers
SOURCE: Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Posted on Oct 05, 2007
  • 9098 Answers
SOURCE: when I open my microwave door, it starts running
In most cases, it's not actually cooking, but instead the fan, turtable and light may be on. Yet it does need attention.
What this usually means is that you have a shorted door switch or a bad door switch mount.
It's easy to tell if it's actually cooking, just place a cup of water inside and see if it heats.
If so, that could mean a stuck relay on the control board. If so, we repair these for customers nationwide with our guaranteed $39.95 service. Far less than a new board.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 19 Answers
SOURCE: constant humming sound
the most common problem with ALL microwaves is the magnatron
Posted on Dec 30, 2007
  • 9098 Answers
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
Posted on Jan 31, 2009
  • 1236 Answers
SOURCE: fan in microwave won't shut off
in most cases, it is the door switch. It usually has 2 micro switches and either one can go bad. Not a hard fix. I would look at the operation to see if the switches are working. If that is not it, could be in the circuit board. Could be too much to fix, maybe buy a new one if it is a counter top type. Otherwise let it run till it quits. Call a repair guy, and have him diagnose the problem. Tell him you will fix it in a month or two so could he write down what you need with the part numbers. This way you do not have to start at ground zero. Then order the parts and fix yourself if you feel brave enough.
Posted on Feb 07, 2009
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Open door and internal fan engages.
One of the door interlock switch could be bad.
Nov 14, 2014 | Samsung 1.8 cu ft Over-the-Range Microwave...
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
Check those 3 micro switches in the door latch assembly
Nov 15, 2017 | Microwave Ovens
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Nov 28, 2017 | Samsung SMH9187 Microwave Oven
Constant humming sound
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
