Question about Kenmore Dryers
Kenmore he3 dryer model #110.8708. Will not start and thermal fuse replaced worked for awhile and has stopped again
  • Kenmore Master
  • 2,160 Answers
There are multiple thermistors
Posted on May 05, 2017
My Kenmore dryer model HE3, 11084836201, will allow me to select the drying cycle, but it will not start. Once I press the start button, it clicks but will not start. Please help!
This problem is commonly caused by a blown thermal fuse located on the blower housing behind the bottom panel. Remove the bottom panel then the lint duct and check continuity of the thermal fuse. You can also bypass the thermal fuse for troubleshooting purposes. Check for blocked lint filter and restricted vent system if the thermal fuse is indeed blown then replace it including the thermistor. Click on the link below for detailed troubleshooting of this common problem.
Kenmore Elite and Whirlpool Duet Dryers Not Starting
Jul 13, 2011 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
I HAVE A HE3 DRYER HAD TO REPLACE THE THERMAL FUSE AND THE THERMISTOR, DRYER STARTED FINE DRYED ONE LOAD AND BACK TO NOT STARTING THE CLOTHES SEEMED HOT WHAT WOULD CAUSE THESE TWO FUSES TO GO. THE AIR WAY...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 27, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Our dryer is overheating, after 20 25 minutes then we smell a burnt plasticy smell, then we let it cool down, start again, it goes for awhile, then stops, then again overheating, then the smell again.
Firstly, you need to stop running your dryer before you do any further damage,
As you haven't specified your brand or model of dryer, I can only give general advice. It's likely that your thermostat has failed in the closed (on) position. The thermostat cuts power to the element when your dryer reaches the correct temperataure.
Most dryers also have a thermal fuse to cut all power to the dryer if they overheat. This functions as a backup safety device and this only usually trips when the thermostat fails. Your dryer is stopping because the thermal fuse is cutting power, but as you can smell burnt plastic, it's likely some damage is being done before the thermal fuse trips.
Stop using the dryer, and check/replace your thermostat.
Please rate this solution if you find it helpful. Thanks!
Oct 31, 2010 | Dryers
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
