Please help reboot mty tab 4 it was rooted and someone haaaaaaaaaaaaard ese it
2 Suggested Answers
  • 1481 Answers
SOURCE: My Tab key won't work even on my USB keyboard...
Use the following keys together....it should work...
ALT + TAB
Posted on Dec 10, 2009
I have a babylock Esante Ese-2 and need a replacement embroidery arm.
You can try eBay or Craigslist for a donor machine. Or, contact your Babylock dealer.
Aug 17, 2015 | Sewing Machines
How can I root Oppo Find 7a? Please help.
Yes you can easily oppo find 7a smartphone. This guide will help root your smartphone and install custom recovery like TWRP on it.
How to Root Oppo Find 7 7a and Install TWRP Recovery
Nov 27, 2014 | Televison & Video
The fan on the MTI Autofry is not working. Everything else working ok. Safe to use until I can get someone in to look at it?
Should get it looked at, the fan can cause other parts to over heat and cause you more problems than just the fan not working. Try to get it to spin by using a pencil (not your fingers) to turn the blades. These fans often stick from grease build up or when going bad from age. Many have a plug connector on the fan and 4 screws holding the frame in place, fairly easy to replace.
Oct 11, 2014 | AutoFry MTI-5 Countertop Ventless Fryer
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
Have a Samsung galaxy tab 2 , 7.0" ...3113 .....4.1.1 want to root need to know what to down load to my pc and how to due it..thanks
Step 1:
1. The following procedure works for Samsung Galaxy Tab 2 P3113 smartphones.
2. Make sure your device have at least 80% battery power.
3. Make sure USB Debugging is enabled
Step 2:
1. CF-Auto-Root to root P3113UECLK7 firmware [Filename: CF-Auto-Root-espressowifi-espressowifiue-gtp3113.zip]
2. Odin 3.07 [Filename: Odin307.zip]
Step 3:
1. Extract Firmware zip file and you will get a .tar file and some other files.
2. Extract Odin zip file and you will get Odin3 v3.07.exe along with few other files.
3. Switch off your Galaxy Tab 2 P3113
4. Now, put the Galaxy Tab 2 P3113 in Download Mode by pressing and holding the Volume Down key and Power button.
5. Then, a warning message appears, press the Volume Up key to continue.
6. Now run Odin3 v3.07.exe as an Administrator because Admin privileges is required to complete the process smoothly.
7. Now connect your Galaxy Tab 2 P3113 with your PC using USB cable.
8. Then a message will arrive under Odin's message box in the bottom left saying "Added!!"
9. Select these files in Odin at respective tabs from extracted firmware folder:
  • Click the PDA Button, and select the CF-Auto-Root-espressowifi-espressowifiue-gtp3113.tar.md5 file.
10. In Odin window, make sure Auto Reboot and F. Reset Time checkboxes are selected. Also, make sure that Re-Partition checkbox is selected, only if you are using a .pit file.
11. Double check everything that we mentioned in Step 9 & Step 10 above. Now, once satisfied hit the START button to begin the flashing process.
12. Once flashing completed, you will see a PASS message with green background in the left-most box at the very top of the Odin. The tablet will then automatically rebooted and soon you will see the Samsung logo. You can then unplug the USB cable to disconnect your device from computer.
Congrats! Your Samsung Galaxy Tab 2 P3113 running P3113UECLK7 Android 4.1.1 Jelly Bean firmware is now rooted. You can now install apps that require root permission.
Apr 05, 2013 | Cell Phones
Can you upgrade Samsung Galaxy Tab OS 2.2 to OS 2.3?
Procedure to update Samsung Galaxy S with Gingerbread 2.3 version:
Before we proceed to the updating process, please note that your phone needs to be rooted because your current file system must be converted to EXT4 which can be done with the help of latest version of Voodoo Lag fix. Also you need to backup all your data as there is a high probability that you may lose data after the updation. And also you must have Busybox in your device.
  • Now, you need to copy the file system-dump-as-root.tar.gz on the root of your SD card after which you will have to run these commands,
adb shell
su
cd /data
mkdir gingerbread
cd gingerbread
busybox tar zxvf /sdcard/system-dump-as-root.tar.gz
mkdir data
busybox cp -a /efs efs
sync
reboot download
  • After this it is time to unzip nsonsgs.tar.zip to nonsgs.tar
  • Now, you will have to flash the kernel with ODIN client with NO PIT and NO Repartition selected. And this is it, Your Galaxy S will now run the Gingerbread 2.3 version. At any point of time if you wish to move back to the Froyo update then you just need to flash it again with the froyo ROM back by using the Odin but before that make sure that it must support the EXT4 file system or else your device may become unusable.
Sep 22, 2011 | Samsung Galaxy Tab Tablet PC
I have an error code for ventless autofry of 417
The error code that you have received is from the Temperature Circuit. Please call the MTI/Autofry Technical Support team @ 1-800-348-2976 ext.112 and they will help resolve your issue.
Thank you,
MTI/Autofry
Nov 29, 2010 | Kitchen Appliances - Others
My leptop not detect USB
Generally, this is a fault of the default power management settings in Device Manager. Open Device Manager, USB Devices, USB Root Hub, Right Click, Properties, Power Management Tab. Uncheck the box to allow the computer to turn off the device to save power.
Repeat on all USB Root Hubs
Reboot
Connect a USB device, see if it is detected.
Aug 09, 2009 | HP Pavilion dv6000t Notebook
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Dec 06, 2008 | fedora Linux Operating System
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
