I have low water pressure light on opal 2 all the time and water is freezing, mains fed and no other issues with water pressure
    President:
  • 1,776 Answers
I would check the screens at the inlet valve. Make sure that they are clean and clear. The problem could also be in the inlet valve assembly solenoids. Hope this helps and best wishes.
Posted on Jul 25, 2009
Is it a mains fed shower
The installation must be in accordance with
Water Regulations/Bylaws.
To ensure activation of the heating elements, the
shower must be connected to a mains water
supply with a minimum running pressure of
100kPa (1.0 bar) at a minimum flow rate of eight
litres per minute (nine litres per minute for the
9.5kW rated model).
For all units the maximum static pressure must
be no greater than 1000kPa (10 bar)
If in any doubt, the pressure should be checked.
Sep 16, 2014 | Home
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Propane fryer is igniting in the gap below the burners
Hi there.
Low gas pressure may cause the tip of the orifice to light up during operation, you have to ensure that the gas pressure fed to the unit is correct. But when this happens after cut-off, the gas valve's main valve is leaking and needs to be replaced.
Regards.
Jul 13, 2013 | Kitchen Appliances - Others
Oil light comes on between services on bmw 318 ti es
Oil light should not come on unless the Level is LOW or the Oil Pressure has dropped below safe operating limits. I would do 3 things
1. Check Oil Level, if low, fill to the correct level and then restart.
a. if the light does not go out....
2. Pull the Oil Pressure Sending unit out and install a pressure gauge
a. if the pressure is in normal operating limits, chances are the Oil Pressure sending unit is bad
b. If the pressure is low, the issue is
1. Oil Pump
2. Engine Main or Rod bearings are bad and a engine rebuild is on its way
May 26, 2011 | BMW 318 Cars & Trucks
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Qca Spa pumps and blower will not come on, water down to 35º f
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
http://hottub.synthasite.com
Feb 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Triton opal shower showing low pressure,when there is no low pressure!
In the top of the water inlet valve at the bottom of the unit there's a plunger that rises when the water is switched on. this activates a small switch at the bottom of the pcb and cancels the low pressure warning. this is free to turn in the valve and over times may rotate stopping the plate on the top from contacting the switch on the pcb. If this has happened just turn the plunger back to the correct position.
Aug 28, 2009 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Washing Machines Logo
Top Washing Machines Experts
