Question about Plumbing
I have no water pressure and there must be air in my lines because the water splurts.
  • 17,093 Answers
We need more information from you about the system. Are you on well, or municipal water? Is it hot water or both?
Posted on May 05, 2017
I have a 1/2 hp gould shallow well pump that takes a long time to reach pressure and shut off. Any advice to correct?Thank you, Kevin
Make sure you do not have any excess air in the line. More than likely there is an air (vacuum) leak on your suction line.
Nov 16, 2017 | Water Water Heaters
Have grundfos jp4 with controller. it will start up in the night when no taps turned on,? and to me it appears to have less pressure when using the hose? is there a pressure adjustment
No pressure adjustment.
Air bubbles in line will decrease pressure... air vent at highest point can help solve problem.
http://waterheatertimer.org/Repair-water-heater-valve.html#air
Possible leak problem on Hot line somewhere, and/or pressure problem.
Turn off all taps and check before and after result on water meter.
If toilet is running it draws cold water... but if you have bad single-handle faucet cartridge, it can draw hot into the line.
Following links have troubleshoot resources:
http://waterheatertimer.org/Low-water-pressure.html
http://waterheatertimer.org/Crossover.html
Oct 21, 2017 | Grundfos Plumbing
White Magic 650H. Why is error code PE displayed and water reuse LED blinking?
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Sep 29, 2013 | Whirlpool Washing Machines
Hello, I've been using the "Whirlpool 25.1 cu.
Maybe trash has made its way to valve and it is partially stuck open. Or maybe all air is not out of line. Run water through dispenser until it stops splurting air and there is a steady stream of water.
Sep 23, 2017 | Whirlpool Refrigerators
My Maytag top load, looks like PAV2300 but not sure, will not rinse. The water drizzles a bit during the cycle and I hear the timer but the machine does not rinse. I cannot force it into rinse. I have to...
Hi and welcome to FixYa. I am Kelly
There is a water level pressure switch inside the top panel that has 3 wires on it and a vacuum line. That pressure switch controls the water inlet valve functions via the timer.
If by chance the pressure sensing line is getting hydraulically locked with water due to some form of obstruction it can cause the symptom you describe.
This pressure switch also controls the start of the spin once the water level has dropped (prevents the wash tub from being a water brake and damaging the motor clutch)
If the water level pressure switch is working normally then the only thing left is the timer.
You can do your own testing of the water level presure switch with an external vacuum hose (3 feet in length) connected in place of the machine hose. (DO NOT drop the machine hose when you disconnect it!)
1. place timer on wash and start filling. LID CLOSED
a. Force air orally into the external line
1) Result fill stops agitation begins
2. place timer in spin LID CLOSED and force air into external line until the pressure switch clicks.
a. START SPIN CYCLE NOW and listen for water pump out
b. release pressure on external air line
1) result tub starts spinning
If it passes the above tests your looking at a timer problem causing your no rinse situation.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
Reduced air flow and pressure
so your saying there is not enough pressure there
Oct 12, 2009 | Air Tools & Compressors
Pump spinning but not getting up to speed then shuts off
You have a pressurized system using a pressure tank.This is a case of an air logged pressure tank. Meaning there is more air than water in the pressure tank. The pressure tank must hold 2/3 water and 1/3 air of its total volume. Installed at the tank is the air volume control to take care of this proportion. Should the air volume control malfunction or becomes defective, the air-water ratio is affected. And then,
the pressure tank becomes either air logged or water
logged.
SOLUTION:
1. Shut the power off, and open the discharge line
gate valve to flush the water in the pipe lines.
2. Open the drain plug of the pressure tank to empty
all the water at the pressure tank.
3. Close the drain plug, and put the power on.
4. Start the pump, and set the flow control valve 1/4
open.
5. The pump will normally run.
Send your e-mail for us to know the results, and for
further assistance.
Jul 04, 2009 | Plumbing
Water collecting when using A/C
My first reaction is that it sounds like a plugged or partially plugged drain line. Clear the drain line by either blowing through it backwards (carefully) or using compressed air. In a worse case the line could be kinked or rotted. Make sure the drain can run freely into its destination. Sometimes the line will need to be disassembled to clean it.
Another cause of this can be static pressure imbalance on the fan...the drain trap should be equal to or just less than in height of the total static pressure of the fan in inches of water column so the water (condensate) is not held back by the fan pressure. Make sure your filter is clean, especially if you have pets.
Apr 20, 2009 | Coleman Heating & Cooling
Plumbing Logo
361 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
