Question about Grohe Plumbing
How do I remove Grohe faucet cartridge that will not unscrew
  • 7 Answers
SOURCE: GROHE FAUCET DRIPS FAUCETS IS A 34-434
yes this is definately the cartridge.You might not have to replace the cartridge.First take the cartidge out and see if their is any dirt causing the water to pass thru the spout.If thiers nothing obstructing the cartridge than you will need to get a new one.
Posted on Feb 02, 2009
SOURCE: grohe ladylux cafe faucet removal
You will need a Grohe Fitting Key to insert into the fixing tube (which is the area after you have removed the Handspray and the Fit spout) and turn counter clock wise. If you don't have Fitting Key, call Grohe at 630-582-7711
Posted on Feb 24, 2009
  • 659 Answers
SOURCE: trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Posted on Jul 05, 2010
  • 19 Answers
SOURCE: I have a grohe ladylux
On this particular faucet you may not be able to reach the part that might be giving you issues in the spray head. However, to take the head apart, on the spray face you will turn it counter clockwise, the aerator will come out at that point and you should be able to see down into the tube to see if there are any obstructions. Also if you are using the little Grohe water filter that goes into the handle before attaching the hose, it is possible that that is clogged especially after 3 years. You should be able to remove that altogether, or contact Grohe for a replacement. If once you have removed all of these and have found no removable obstructions, then the only other thing to do is contact Grohe for a replacement spray head which I believe they are still available. Hope that helps.
Posted on Aug 18, 2010
Grohe concetto faucet, 34270, leaking at lever handle when moving lever up and down.
It's a complete cartridge that you need to replace. Contact Grohe and they should send you out a new cart. under their limited lifetime warranty
Feb 16, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
I have a grohe ladylux that is almost 3 years old. the water pressure is low. When i unscrewed the head water flows well, but when the head is back on it rens slowly. I,ve cleaned the screen by unscrewing...
Aug 18, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Faucet is running slow
I think that there is a screen in the inlet side of the spray head, the hose just unscrews and you can rinse the screen out with the water coming from the hose
Jul 01, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Mixer tap in kitchen hard to turn on and off
It is a simple matter of on o-ring being out of align. REmove the valve cartridge fromthe faucet by first shutting off the water at the shut-off valves. Then remove the handle by means of loosining the set-screw on the front side of the handle. Then remove the valve cartridge by unscrewing the packing nut that surrounds the shiny stem that the handle was connected to.
Once that is removed then the cartridge will slide out, probably with a bit of force. Replace the o-rings and any other washers that may be there and coat liberally with plumbing grease before re-installing. This should fix you right up.
Bring the old cartridges, rings and washers with you to your home improvement store to make replacing easier. Should be about $15-$20.
Good luck.
Apr 25, 2009 | Grohe Classic Kitchen/Bar Faucet ...
Grohe kitchen facet 33 759 clogged
check the airraider on the spout of your faucet it unscrews and can build up with junk and sadly some times sediment works its way in to your faucet and clogs the stems and with a grohe faucet being as pricey as they can be i sugest replaceing the stem as aposed to getting another grohe faucet
Mar 28, 2009 | Plumbing
My Grohe Kitchen Fawcett lost water pressure, is their a manual online available?
make sure you check the strainer that unscrews from the spout. SOmetimes these clog from sediment. ALso check the supply valves to the faucet (sometimes there is sediment in these--opening and closing helps) you may have to remove the cartridge(s) depending on you model number. You can probably download the manual at homeappliance.manualsonline.com
Jan 04, 2009 | Grohe Classic Kitchen/Bar Faucet ...
Plumbing Logo
192 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
