Question about Honeywell Televison & Video
I have a honeywell (Alliance) T8001 series unit and the display has gone completely blank but the fan switch works and so does the cooling and heating i think. I need an answer ASAP
There are no LED lights and the whole thing works but its like a buff man with no eyes for comparison
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
  • 118 Answers
SOURCE: problem with thermostat (honeywell rth111/221).
should be installed with
1) red to rc and jumpered to rh
2) green to g
3) yellow or blue to y
4) white to w
to test: remove t-stat connect white and red - furnace should operate normally unitil you disconnect.
if it does replace t-stat
Posted on Oct 27, 2009
heatman101
  • 43501 Answers
SOURCE: honeywell t8000c display is blank, unit doesnt run
I would say that you have one of two issues. Either your thermostat is bad or you do not have 24v coming from the heating unit. In this case the problem would be in the low voltage circuit of the heater. At the heater you should have 24v AC when you place an electric meter across the R terminal and the C or W terminal. If you have no vaoltage across the R to either the C or W then you have a bad transformer or a blown fuse in the furnace. If you do have voltage ther and also at the t-stat then the t-stat has gone bad, replace it.
Posted on Nov 14, 2009
GeOrGeEtUk
  • 332 Answers
SOURCE: display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Posted on Jun 06, 2010
Honeywell T8000 thermostat. the display went blank after removing and reinstalling.
Bent prongs, do not remove screws.... Do yourself a favor and set that tstat in the trash can and walk away from it. Most of the time when the prong is bent(enough), it separates the prong from the circuit board. Now the buttons actually have small, metal magnet like pieces inside the buttons. They need to be placed back like the factory had them, if they had fallen out when you took it apart. Not sure what happened to it, but in this scenario, I'd set it aside and start fresh.
Sep 03, 2017 | Honeywell Heating & Cooling
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
I have a honeywell programmable therm that worked fine last season - didn't turn on during the summer as didn't need A/C. It is currently displaying the correct day and time, but the temp is not...
Hello my name is Heath it will be my pleasure to assist you. Your thermostat may be on the blink and need to be replaced. But first lets try a couple things first take the batteries out of the thermostat and let the display go completely blank ( aprox. 5 mins.). While that is going blank go to the indoor air handler and turn the power off to it either from the switch or the inside panel box. Then once the display has gone blank turn the power back on and put the batteries back in. Then set the switch to cool and turn the temperature down and press hold and try it like that to see if it goes back to heat if it does then the thermostat is changing the temperature on its own and going into heat mode and will need to be replaced.
Sep 21, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell T8001. The display will not come on. It was on this morning. I unmounted and mounted the unit. The circuit breaker was not tripped. I have no idea where the fuse is and it is on the...
The power for that comes from the air handler or furnace...
Check for 24v power there...the cover may be loose or the transformer went bad/fuse blew...
heatman101
May 11, 2011 | Honeywell Heat/Cool Thermostat
Honeywell t8000c display is blank, unit doesnt run
Nov 14, 2009 | Honeywell Electronic Programmable...
Honeywell TH6000 series thermostat does not turn Fan on.
It's one of two issues; either the wiring to the thermostat is incorrect, or possibly you have an open ground. Depending on your system the wires at the thermostat end might have to pair up on one lead. go to where your unit is and look at the schematic for the control board, it will let you know what color you are looking for on the blower lead -- then make sure the corresponding color matches at the thermostat. Knowing the make and model of you unit and the board on it would allow me to be more specific, hope this helps you out some in the meantime.
Jun 17, 2009 | Honeywell Focus 6300B 5-2 Days...
Display is blank and furnace fan stays on
Remove wires at tstat Turn switch for furnace off than on.
touch the red wire to the white to simulate a call for heat.
Or Touhc red green and yellow to simulate a call for cool.
If that works get a new thermostat.
May 10, 2009 | Heating & Cooling
Nov 24, 2008 | Honeywell Electronic Programmable...
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Televison & Video Logo
60 people viewed this question
Top Honeywell Televison & Video Experts
mikemail1
Ron Durham
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
