Question about Ricoh Office Equipment & Supplies
How can I clean the transfer belt of the Ricoh Aficio MP4000?
I am trying to fixed the error code Sc863-06 of Ricoh Aficio MP4000. Can you help me fixed the transfer belt.
3 Suggested Answers
Ickoajnc
  • 203 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
  • 10291 Answers
SOURCE: how do i clean the drum and/or charge roller on a ricoh aficio mp4000?
NEVER attempt to clean the drum. Touching it will leave your finger print on every printed page. Scratch it slightly and it's ruined so never think about cleaning it. Look for printer roller cleaning sheets at your local office supply store. They are sticky on both sides. You run a sheet through the printer several times to clean paper dust off all the rollers in the paper path.
Posted on Oct 23, 2016
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
Error message sc.440 on ricoh mp4000 copier
It happen when there is a slight load tansfer belt. What l did was..clean all the rollers & bushings underneath the transfer belt. Threre are 3 rollers..4 bearings & 2 bushings. Remove all stains.. And also you could polish the surface of the transfer belt by using car polish liquid to smoothen the belt rotation
Jun 28, 2013 | Ricoh Aficio Mp5000 Lanier Ld050
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Jan 21, 2010 | Office Equipment & Supplies
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
Feb 22, 2009 | Ricoh Aficio 450 Copier
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
37 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
