Question about Asko Dishwashers
How do I take out the old control panel of my Asko 3531 dishwasher and install new one.
SOURCE: ASKO Washing Machine WM220(ASKO 20605)-Control Panel
IS 2 looks like a MOSFET on my machine
I'm not sure on the Manufacturer - Their logo appears to be a large streaked "I"
The numbers on my mosfet read:-
H542
TOP200YAI (this last digit could also be a 1)
PC0288
Cheers from a fellow busted ASKO consumer.. :(
Mine appears to be motor or motor controller related, so if you don't fix yours, I'd be happy to take a few parts off your hands. ;)
Posted on Feb 24, 2008
  • 24 Answers
SOURCE: ASKO D3350 Dishwasher won't work.
possible failure of electronic board expensive to fix. May even be suprresion capacitor. A lot of brands used suppression caps on the ac input to filter out unwanted noise. When these blow they stink and some even arc but one thing is sure they cut the power to the rest of the dwasher may even throw out your power.Make sure it is switched off and unplugged before dismantling it.
Posted on Oct 08, 2008
SOURCE: Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
Posted on Jun 07, 2009
  • 3741 Answers
SOURCE: I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Posted on Aug 28, 2009
Testimonial: "Thank you so much for the quick and informative answer. It is greatly appreciated. "
  • 3741 Answers
SOURCE: Leaking dishwasher
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses--Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Oct 11, 2009
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
I have an ASKO D3251. Door free falls when opened. No longer has tension to control downward movement.
Your springs are faulty.you have two of them and will need to pull the unit out and inspect.usually on asko dishwasher you have to order the whole tension spring assembly .
Jul 29, 2012 | Asko 24 in. D3250 Built-in Dishwasher
How do I remove the cerculation pump on an asko asko Dishwasher D 1716
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Apr 22, 2010 | Asko D1716 Built-in Dishwasher
New Asko Dishwasher. Both the appliance store
Make certain the door switch is making contact and the switch is good. Open the front panel and trace all the wires,especially where they go from the door to the underside of the DW. Look for a broken or pinched wire.
Jul 06, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
New install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Jan 01, 2009 | Asko D1976 Built-in Dishwasher
Asko d1876 (black)- despenser problems
it sound like you need a new pcb,if the dispenser is making a buzzing sound,then thats it remove the control panel and see if the tracking is burnt anywhere,also replace the wax motor on the drying vent.
Feb 22, 2008 | Asko D1876 Dishwasher
Dishwashers Logo
32 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
