Question about Pyle Audio Players & Recorders
Home theater stuck on high volume
My Pyle home theater receiver pt1100 when powered on, works only on max. volume. Please help. Thanks.
MrScary66613
  • 1990 Answers
SOURCE: OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Posted on Jan 03, 2009
freetek
  • 5568 Answers
SOURCE: My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Posted on Feb 01, 2009
SOURCE: Time Warner Remote Code to work volume for Philips Home Theater
after much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though
Posted on Feb 02, 2009
SOURCE: volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Posted on Apr 23, 2009
Volume control stuck at Max Volume. Remote also not working. How to rectify the problem?
check the batteries in the remote the do go flat, all tv and home systems have buttons that will all that a remote does .
Feb 05, 2016 | Audio Players & Recorders
Pyle PPHP159WMU: Just received this used unit and the bass speaker tends to cut out the louder the volume is set. Does the battery have to be fully charged for the unit to function properly?
The speaker may have a current sensing device to avoid damage under high volume conditions. Also check the setting of your bass control. Every 3 db increase in setting doubles the power going to the driver and it is easy to over drive the unit at high volumes if your bass control is not on flat.
Feb 03, 2016 | Pyle Audio Players & Recorders
Volume goes up by itself
First, check your software firmware version and see if there is an update. If available read your manual how to do a firmware update using your USB port, if you don't have a manual, check Bose.com for their online manual and firmware updates. I had a different problem but the firmware update solved it. Another tip to increase the depth of your bass, while doing the adaptiq process, cover your bass speaker with a pillow, this will make your bass more deeper. You need a second person to cover your bass module with a pillow. in this way, the adaptiq process cannot hear the bass sound and it will increase the bass. You might need to do this several times until you get the desired bass sound. If you have not setup using adaptiq, your better off not using adaptiq, the sound is much better. Hope this helps.
Nov 18, 2013 | Bose Lifestyle V25 Theater System
Hi Jenny,normally to resolve the problem you are experiencing,I strip the volume control and service it.You need to take it to a technician to have it repaired.Thanks Ravi
Nov 21, 2011 | Panasonic Home Theater System System
I have a LG Record reciever home theatre model is LH-RH9691 and im having a problem with the volume only when the radio is working. It can only turned up slightly when set to max volume. But when...
in lg home theater system in video mode the complwte speaker will work and in mp3 only two will word .the radio get only a min volume in lg due to the range of antina
Apr 25, 2011 | LG Audio Players & Recorders
Bose 321 System Stuck on Hotel Mode!
Hey, try this out
-Press Enter and On/Off on the media center , on standby mode
-now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON
- on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off.
Thanks
Brigade
Sep 25, 2008 | Bose 3·2·1 II System
Rca rtd215 home theater system
some of them do this to save the speakers but try unplugging it over night and see if that reset it hop this inform you more.
P.S. I own two of them..
Mar 09, 2008 | Audio Players & Recorders
PLEASE HELP with PYLE PLUS GXA-280A
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Sep 24, 2007 | Pyle PLA985R Car Audio Amplifier
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
