Question about Garmin GPS
Garmin gps196 buttons unresponsive - Garmin GPS
Garmin 196map buttons unresponsive
One of the buttons may be stuck down, disabling the rest.
May 05, 2017 | Garmin GPS
Garmin troubleshooting
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 29, 2014 | Garmin Forerunner 405 Watch
I have a Garmin Nuvi 650 with an unresponsive screen...can anything be done? Thanks
Power off your Garmin 660 unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
To back up your Garmin.
  • From the garmin drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  • After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Garmin, but be sure to rename it 'temp.gpx'.
  • On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Garmin where they are actually stored
  • This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    Thanks for using FixYa
    May 20, 2011 | Garmin Nuvi 660 GPS Receiver
    Garmin is unresponsive. Won't power up or turn
    I have a Garmin c340 that would not turn on.
    I found the hidden reset button and it works now.
    With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
    Mar 10, 2010 | Garmin StreetPilot c340 GPS Receiver
    Etrex Garmin Legend GPS is 3 years old. Is completely unresponsive even with new batteries. Any ideas to try?
    Have you hooked it up to your PC and updated the unit's internal software via This might solve your issue. Pls let us know if it does.
    Jan 01, 2010 | Garmin eTrex Legend GPS Receiver
    Garmin 775T screen is frozen
    If you hold the power button down for about 4 seconds or so, it should ask you if you want to power off. If the screen is still unresponsive, if you hold the power button down for 10 seconds, it will hard reset the device, powering it off with no screen input needed. At that point, I would check the firmware and make sure that it's up to date, as well as try to figure out how old the battery in the device is as well and consider replacing that as well.
    Nov 09, 2017 | Garmin n?vi 775T Car GPS Receiver
    My garmin nuvi 670 touch screen is not calibrated
    Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
    - Jim
    Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
    GPS Logo
    Top Garmin GPS Experts
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
