Question about Keurig Coffee Makers & Espresso Machines
Keurig B77 Platinum Series stuck on Brew setting.
Cleaned the needles, flushed the water several times(got chunks out then water was clear). It started to brew /run water into the cup again, but setting is stuck on 'Brewing' and cannot switch to other sizes
    Problem Solver:
  • 12 Answers
I heard that these Keurig coffee makers can't be totally cleaned inside the rubber hose develop a mold that's nasty .
Posted on May 05, 2017
How do I fix a Keurig V1255 with a flashing LCD display?
Keurig Platinum Reset for the Not Ready Light - YouTube
? 1:21
https://www.youtube.com/watch?v=xjWIQpttTc8
Jun 22, 2010 - Uploaded by Lsailor1
This is a reset method for using on the Keurig Platinum B77 coffee ... Show more ... set to brew in morning ...Missing: v1255
Fix Keurig Vue V700 Not Brew
Nov 14, 2015 | Vue V1255 Professional Brewing System...
Keurig B70 automatically pumps water when turned on
When you purged the lines or tubes retained debris and need full purging and flushing.
May 30, 2012 | Keurig Platinum B70 Coffee Maker
Only brews half a cup on the largest cup setting?
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 26, 2011 | Keurig Special Edition B60 Coffee Maker
Won't brew only drop at a time wiuth coffee grounds ]
5.Power on machine.
Mar 26, 2011 | Keurig Platinum B70 Coffee Maker
I have the issue of slow flow and the water goes to the bypass at the same time as brewing so I get "short" cups. Did the de-scaling... but no resolution. I can even get good flow from the...
Hi, Don, W/D here.
There's not a lot of troubleshooting advise out there for Keurigs, but here are a few things to try:
Try brewing a cup, without the K-cup in the holder. As the brewing cycle starts, hold your finger over the return line to the reservoir (lift the lid to the reservoir; it's in the top, back, and it's white). Careful, there could be hot water there. Plug the hole off with a gloved finger and this will run the cycle longer, and may unplug it. De-scaling may have moved some of the accrued sediment into the dispensing lines.
If you haven't tried it, try cleaning the upper and lower tips. Take an ordinary paper clip and straighten it into an "L" with the short side about 1" long. Pass this end up into the upper piercing needle (careful-sharp!) and down into the lower needle. Sometimes, it takes several tries to clear the needles.
If you try the needle clearing, then try plugging off the by pass. Repeat as necessary.
Hope that this helps you, --W/D--
Feb 05, 2011 | Keurig B60 Coffee Maker
Water is getting to the k-cup but does not come out unless I take the cup out and turn it around and puncture a second time. clear water runs through with no problem
Hi, W/D here.
Take an ordinary paper clip, and straighten it into an "L", with about 1" on the short side. With the Keurig opened as it would be for inserting a K-cup, locate the upper and lower puncture needles. Take the paper clip and use it to pass into the hollow needles to free up any debris that may have collected in the needles. Be careful, as the needle tips are very sharp. Do the lower needle as well. This should improve the quality of your brew.
Another thing that will help is to de-scale the machine with white vinegar. This is done by emptying the reservoir, and re-filling about half way with white vinegar. Then, brew two cups, which will draw the vinegar into the inner pot. Let the vinegar sit in the machine for several hours, and then empty the reservoir. Refill with clean water, and flush the water through the machine, one cup at a time, until no traces of the vinegar can be detected. This will keep your machine brewing at it's peak performance. Most folks perform this cleaning every six months or so, but you really need to do it according to the quality of your water, that is, use six months as a maximum, and more often if necessary.
Hope this gets your coffee back to just right. I KNOW how important that is!
Best regards, --W/D--
Jan 27, 2011 | Keurig B100 Coffee Maker
The pump does not work like before, when brewing cycle begins, water flows from the top of the water tank into it. The brew cycle comes up short, about a 3rd of a cup, and after the brew cycle light...
We had the same problem with our Platinum Keurig - the water would dribble out and stop before a full cup was brewed. It turns out the 3 openings to the upper needle were clogged (the Keurig specialist helped us). You have to pull off the little mushroom-shaped gasket first, then use a straightened paperclip and stick it into the 3 openings on three sides of the upper needle, moving it around for 15 seconds in each opening. Replace the gasket and then, by not inserting a k-cup, flush plain water through the needles for 3 different 6-oz brews (use a measuring cup to check). If you are still getting short-cups, you will likely need to call customer service. Make sure to clean the lower needle too - the instructions are in the book - but be careful not to break the funnel cover when removing. Good luck!
Jan 17, 2011 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
