Question about Bell Televison & Video
Replacing a hd6100 bell receiver to hdpvr9241 do I need something else to make it work
Motor no longer seems to work - have already tried new batteries
If the motor is exposed to the elements, rain water may enter the casing and freeze up the motor shaft, brushes, and windings can short out. May need replacing.
Mar 17, 2014 | Sport & Outdoor - Others
We have purchased a portable flat screen t.v. from WalMart and would like to know which company it would be compatable with for the remote as we are wanting to program 1 remote to work on the t..v, and the...
To brad6134,
We have a bell receiver and recently changed to the HD and got a new receiver and new changer. You didn't say if you have a Bell dish. We have and when went to HD , we now only have to use one changer. Before that with Bell, we needed two changers. Hope this helps.
Apr 10, 2011 | eMachines E620 COMPATIBLE LAPTOP LCD...
My 3.2 IR 166173 BELL remote wont work on my bell reciver
Ensure that the TV is turned on. Turn the Bell receiver on manually (at the receiver). Remove the batteries from the remote. Press the "Power" button on the remote until no buttons on the remote light up (a half-dozen times). The satellite service (your Bell service) will likely have turned itself off in the process. Replace the batteries in the remote. The remote should now work as "normal".
Nov 26, 2010 | Televison & Video
How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Oct 13, 2009 | Bell Televison & Video
Color is messed up
Solved. I tried the 2nd Bell receiver and Color is fine now.
Took the "questionable" receiver to 2nd TV. Satellite was awaiting connection message, then it said it was downloading a software update to the receiver. After the download completed, the color was fine.
Nothing to do with the JVC TV, it was related to a software update from Bell Expressvu to the 2700 card/receiver.
Mar 16, 2009 | JVC AV-32D305 32" TV
Bell Express Vu 3100
Check in ur television option , try finding the problem by thinking the problem is not in the bell receiver , because im almost sure its not ... Give it a try im sure its worth it
Feb 05, 2009 | Samsung HCN4226W 42" Rear Projection...
Bell Expressvu 2700 satellite receiver av inputs
had my 2700 reciver unpluged for awhile now can't my channels back can you give me any idea how to fix this
Jan 01, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Bell Televison & Video Experts
ray gallant
Are you a Bell Televison and Video Expert? Answer questions, earn points and help others
