Question about Emerson Televison & Video
Emerson model EWD7004 DVD player - disk wont spin. The laser moves back and forth a few times. It ejects fine, and have tried other discs...
I noticed the movies freeze a few times, but just wrote it off on a bad library rental.
SOURCE: sonyplaystation2 model scph 70002
hi i have a problem with my slimline ps2 when i boot up the disc will not spin so it wont read it i have cleaned the laser but to no avail. can you help with this problem?the model is scph-75003
Posted on Dec 24, 2007
SOURCE: Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Posted on Dec 29, 2007
SOURCE: Toshiba SD-3980
read that
Posted on Mar 23, 2008
  • 5 Answers
SOURCE: My dvd player freezes when I view rental/bought movies
Is the player new? If it's a new DVD player and still under warranty, I would return it, exchange it or possibly, consider changing brands: perhaps to a Phillips brand DVD player. After all, the Phillips corporation guarantees its DVD players will play everything, just read the box in which the player's packaged - it's the best bang for your buck. With DVD players being so inexpensive these days, the best option is to buy new. Keep computing Chomskyites.
Posted on Jan 12, 2009
  • 456 Answers
SOURCE: my Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Posted on Jun 07, 2010
Emerson DVD Recorder
sounds like what your doing is correct, See if you can locate a reset button on it and reset it. Did you try connecting to the TV that it worked on previously? Let me know.
Nov 10, 2007 | Emerson EWR20V4 DVD Recorder/VCR
My Sony DVP-CX995V quit playing DVD's. I was listening to a CD, stoped it, went to menu, picked a DVD and bow it say's " Cannot Read Disc " On ALL of My DVD's. All CD's & DVD's are storebought. I've had...
does the spindle motor even try and spin the disk? Pop the top (8 screws) and watch the loader grab a disk and place into transport. The disc should immediantly start to spin and the little laser should scoot back and forth looking for something. If the disc never spins but the laser is moving, you may have a bad motor, or a bad pickup (transport mechanism includes motor and laser pickup). A replacement for this model is about $125 but you can get the same part out of a cheap DVP-S360 for about $20 on ebay. Just make sure you ask if it works before you buy it on BOTH CD and DVD as its 2 different lasers in that part.
Sep 09, 2013 | Sony DVP-CX850D DVD Player
Wat should i do when is displays no disc
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
Memorex dvd-r 16x wont work
It could be the dvd there is different types of dvds that some dvd players cant use.
Mar 29, 2009 | Emerson EWD7004 DVD/ CD Player
DVD player: all disks freeze or skip at same point.
with some models it's very sensitive to being level. try moving your dvd player to a common flat area. see if it's a little rocky or placing a single piece of paper under one of the corners...I had a dvd player that would freeze on every disc and since I moved it to the botton of the cable box it no longer locks up. Worth a try.
Jan 04, 2009 | Denon DVD-800 DVD Player
Technical support needed can't get player to eject disc
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
DVP642/ 37 DVD player says "NO DISK" with any disk.
Usually if there is a NO DISC error, and the lens is verified clean, there is either dust in the laser assembly (use a can of compressed air to clean it out) or a loose laser assembly cable. Also check to make sure the lens can bob (wiggle around), and that it can slide back and forth.
The emergency eject is underneath, its a small slot. Insert a toothpick at one end and slide to the other end to open the tray.
Oct 28, 2007 | Philips DVP642 DVD Player
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
Jul 24, 2006 | Emerson EWD2203 DVD Player/VCR
hi try this: a can of compressed air a narrow hose open the discs drawer try to locate the laser eye with some light and clean it if this wont work its not a teamate no more good luck
Feb 18, 2006 | Emerson EWD7004 DVD/ CD Player
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
