Question about Kenmore Washing Machines
I have a Kenmore Elite front loader washer, model #796.40311900, the washer spins slow not fast as it should when the green light is on spin. The digital readout works normally.
When the washer was set on rinse and spin 20 Minutes , the drum would not spin fast, it would spin slow and sometimes speed up a little and it would take about 2 1/2 to 3 hours for the timer to count down from 20 minutes down to 1 minute and never finish the cycle when the GREEN light was on spin. Everything works normally, had a code but went away after washer reset.
  • Gene May 07, 2017
    """"""""SOLUTION"""""""" """""""UNPLUG THE WASHER FROM THE AC OUTLET""""""" ALWAYS USE CAUTION AND COMMON SENSE WHEN WORKING AROUND ELECTRIC AND WATER. This should work for several Kenmore front loader washers and models.... The problem is the wire harness that goes to the washer drum motor. There are two connectors, one BLUE and one WHITE, the BLUE connector is for the motor and the WHITE connector is for the stator. These connectors are located on the back of the washer to the left after removing the back panel. These connectors have a plastic bag over them to keep them dry. ( FOR ME, MY PROBLEM WAS THE WHITE WIRE ON THE WHITE CONNECTOR, THE WIRE HAD BROKEN BECAUSE IN THE FACTORY WHEN THEY WERE MAKING THE WIRE HARNESS THEY MADE PERFECT CIRCLE CUTS AROUND THE WIRES "SO CALLED STRESS CUTS" TO PREVENT WIRE BREAKAGE, BUT ALL IT DID WAS MAKE THE WIRE BREAK EASIER), the break was where the harness came down to the bottom of the washer, it rests on a plastic clip with a wire tie holding it to the plastic clip. "THIS IS WHERE MY HARNESS HAD THE BROKEN WHITE WIRE", it broke because they did not leave enough room for the harness to flex when the drum was spinning. Remove the damper/rotor its ONE CENTER BOLT,( was easier for me to get the connector off ) be careful when removing the connectors from the motor and stator. Disconnect the harness from both the blue and white connectors, from the motor side, and the zip tie holding the harness to the plastic clip on the bottom of the washer. There are also 3 plastic clips holding the wires stationary with 3 Philips screws. Use an ohms meter to check for wire breakage, FLEX THE WIRES WHEN CHECKING THEM TO MAKE SURE THERE IS NO BREAKAGE, remove the white tape, easier to cut it "( CAREFULLY )", and visually inspect the wires. """""MY WIRE REPAIR""""" I cut the wire back and soldered in a short wire extension, ( Same gauge or bigger not smaller ), and used heat shrink wrap to protect and seal the wire from moisture and shorting out. Use a good 3M electrical tape to re-wrap the two harnesses together and don't forget to put the connectors back in the plastic bag!!!!! If no problem is found check the rest of the harness going to the power control board. This fix should get your washer up and running again. """"""""""""ALWAYS USE CAUTION WHEN WORKING AROUND ELECTRIC AND WATER, BE SMART""""""""""""
  • 209 Answers
SOURCE: Washer won't stop spinning
i am a recently retired appliance engineer of 20 years, if the fault is not right after he has called then write to the manager of the company, if he is sole operator then write to him, explaining it like you said above, ask that the engineer stay and watch till the very end of the cycle as thats where the fault is, if he has already worked on the machine fetch them back? alternatively just ask a different engineer who knows what he is on about, to me this sounds like a circuit board problem either the timer or main pcb module, i presume this is a computer control washer with a digital display, hope this has helped you at least as to where to start, thank you.
Posted on Sep 13, 2007
Jimster
  • 240 Answers
SOURCE: Kenmore 94802 - Goes through all cycles.. Doesn't stop after last spin cycle.
I hate to say it, but it sure sounds like a timer problem. There are contacts inside that move and switch items no matter what setting its in. Its a possibilty that the power contact is stuck closed and when you manually turn it off it breaks contact. The job to replace is really not that hard, remove console (unplug unit first), mark your wires, then just replace. The part though is a touch expensive (131789200 Sears Part Number). Probably would be a little cheaper than buying a new unit I guess. Let me know if you need any further information. Jim
Posted on Nov 05, 2007
SOURCE: LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Posted on Dec 19, 2007
Krazytech
  • 725 Answers
SOURCE: 14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Posted on Aug 13, 2008
SOURCE: Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
Posted on Dec 11, 2008
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Why is the timer is longer than it used to be. each load is about 20 minutes longer
Old washers used a large amount of water and detergent with a agitator scrubbing your clothes. Newer washers use a third of the water and soap as your clothes "flop" over and thru the detergent solution. So you need more time to wash. Also the spinning and rinsing are different. The speed of spin is twice as fast as the older standard washers were, to extract most of the water.
Jun 01, 2014 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Kenmore front load washer: 4172952990. Does not spin. Clicks... at the beginning of a cycle it will spin for a few slow spins, then nothing. Had the Sears technician in. Said that it was the Speed...
Our kenmmore front loader is having a problem with the pump. When it empties there is dirt with the water. Is there any way I can get at the pump and clean it? It is working 70% and as long as I have the drain hose on the ground the water will drain. When I shake the hose dirt comes out and sometimes it says F21. Can anyone help.
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Kenmore 110 washer drum spins with lid open during Rinse/Spin
Slow agitator could be linked to shaft bearings going south. Pull the agitator off and check the block on top of the shaft. With everything turned off, try to turn the shaft. It should turn freely both ways. Other things to slow down the works could be a very worn drive belt from the motor.
The lid switch problem seems to be a wiring short--trace the wiring back from the switch to where ever it ends up (at the timer?). If it winds up at a relay, the contacts may be stuck together. It would be nice to have a wiring diagram--ah well. Don't know if any of this helps, good luck.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
44 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
