Question about Samsung Refrigerators
Defrost cycle on samsung american style fridge not switching off unless power is disconnected
SOURCE: Samsung, american style fridge
We had a service tech service our fridge for the same problem. Although the ice that was dispensed was not as fine as crushed ice, mainly chunks. In any case, he said this is a known problem and is typically resolved by ensuring the freezer temp is not set at the maximum setting. Ours is currently now set at 3 bars and is producing cubes. Not sure if reducing the temp was the ultimate fix as he also replaced the ice maker.
Posted on Aug 05, 2007
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
Hi my Samsung fridge is freezing up? What do i do?
samsung fridge freezer problem click here
hi what model do you have - if its the american style one
fridge freezer up is a common prob with samsung
you could have a look on youtube - there a guy who has a dedicated youtube - samsung fridge freezer repair channel
heres one of the videos >>>>>>ebay links below videos where you can pruchase spares
hope this helps , if you require parts look under youtube videos as there are links you can click onto that will take you to this guys ebay samsung spares shop ..">
Dec 28, 2010 | Samsung Refrigerators
Hi there- recently my samsung fridge began to make a bit of a knocking noise like the fan was dying down whenever I opened the fridge door. Now my fridge won't cool down below 58 degrees. From what I can...
It sounds like the defrost is not working properly and ice has built up inside where the fan is and the ice is restricting normal operation of the fan.Try fully defrosting over 24 hours if possible the defrost heater will still need investigating.
Hope this helps.
May 18, 2010 | Refrigerators
Samsung SR-S2028DVW american style FF keeps defrosting
I would suspect the thermostat or the defrost timer is malfunctioning.
Jul 18, 2017 | Samsung Refrigerators
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
American style fridge freezer, making sounds like water dropping on to hot surface behind louvred vent in freezer section.in
unit is in the defrost mode nothing wrong with the unit it is melted ice now water that is landing onto the defrost heater and siziling as it evaperates not to worry nothing is wrong
May 27, 2008 | Samsung Refrigerators
Apr 01, 2008 | Refrigerators
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
