Question about Frigidaire Refrigerators
Frigidaire refrigerator FRS6HR45KS0 beeps 5 times every minute
Water will not work. Ice is not made. Front door controls for water and ice will not work. Refer side gets cold. Controls for increase/decrease cold work on both freeze and Refer. But still constant beeping, no ice, no water. Solenoids Ohm out @ approx. 400 ohms each. Some have said "5 Beeps" is for door open alarm, but door lite and control lites go out when switch is pressed. You can see them go out before door is closed completely? Is it possible switch opens back up after door is shut?
  • 262 Answers
SOURCE: No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Posted on Dec 17, 2007
TheMobilian
  • 8220 Answers
SOURCE: We have a GE Monogram side by side
Use this GUIDE
Posted on Aug 30, 2010
  • 1796 Answers
SOURCE: front panel just beeps.
HI!!
Note: If dispenser is active for more than five minutes, an automatic lock out sensor will shut down power to dispenser area. See Dispenser Lock/Unlock for unlocking information.
The Dispenser Lock/Unlock affects all keypad functions.
To Lock Dispenser: • Press and hold the Lock/Unlock button for three seconds. A green indicator light above the button will illuminate when the dispenser is locked.
To Unlock Dispenser: • Hold the Lock/Unlock button for three seconds. The green indicator light above will go out.
To Dispense Ice and Water: • Select Water or Cube ice mode by pushing button on dispenser control panel. A green light above button indicates mode selection. • Press container against dispenser paddle. When dispensing ice, hold container as close to chute as possible to reduce spraying.
Posted on Sep 12, 2010
  • 5370 Answers
SOURCE: i have kenmore 253.54622402 side
As per this it indicates that the ventilations are getting blocked after few hours.First the air was flowing from damper but after one hour it stopped flowing air from damper.Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it.------------ The working procedure of this Kenmore side by side refrigerator is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fresh food section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer thaws after few hours.---------
You can get required parts from sears part direct online site or from repairclinic.com site.
To test defrost thermostat you can test this way:---
The defrost thermostat is difficult to test since many refrigerators use different fixed temperature settings and unless you have a very accurate temperature test device the test will not provide proper results. Now you can take the defrost thermostat out of the unit and place the element only in a glass of ice water. When the element is cold it should have continunity between the two wires.------ The meter should not show a reading if the thermostat is turned off. If a reading appears, replace the thermostat.
When the thermostat is turned on, the meter should indicate "0" ohm or .3 or .2 on a digital readout. If it does not appear as "0" ohm or .3 or .2, replace thermostat.Turn the thermostat on and place each probe on either side of the thermostat so meter reads "0" ohm or .2 ohm digital. Put water and some ice in the cup. Temperature should be 32 degrees. If, after four minutes, the meter does not reflect infinite or .0000 on the digital meter open circuit, replace the thermostat.----If thermostat checked out ok then check defrost heater connection.The defrost heater is connected to the side of evaporator coil in the freezer section.If this defrost heater is faulty then it will not melt the ice getting collected on the evaporator coil and due to that defrost system will not be able to function as required.Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.-----------
Now to see where defrost heater is located.Please click on this link below and see part number 14 on the diagram.And part number 15 is evaporator coil.And part number 21 is thermostat.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/R0405135-00006.png
This will help. Thanks. Helpmech.
Posted on Jan 20, 2011
imufo2
  • 3773 Answers
SOURCE: Have Model #MF12266AES Maytag. The
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 07, 2011
4 year old Frigidaire refrigerator beeps 5 times every minute with the Hitemp it will seem to reset and turn on, but it is not cooling the refrigerator. Freezer and ice/water all work great.
Hi, I'm had a problem in my refrigerator like that
I'm changed the thermostat.
This problem gone away, and never again to now
It was three years ago
Jul 01, 2017 | Frigidaire Refrigerators
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Apr 25, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
Beeps about 6 times when fridge door is opened.
Mar 11, 2015 | Refrigerators
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker water dispenser is stuck in the on position
The problem is fixed. I think the drinking cup jarred the push bar activator, causing it to be stuck in the on position. After pushing this activator, it cleared the problem. Thanks for your follow up.
Jun 21, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
71 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
