Question about HP LaserJet 3055 All-In-One Printer
Scanner error 6 in HP laserjet 3055 - HP LaserJet 3055 All-In-One Printer
  • ras408 May 11, 2010
    this problem rise when printer was working (scanner error 6 in HP laserjet 3055)
    scanner error 6 in HP laserjet 3055 when we start scaner
  • 42 Answers
This is a service repair error.
These steps you can try yourself, else you have to get to a HP repair centre:
You can perform a "NVRAM INITZ"
Follow these steps
-switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required.
Posted on Jul 25, 2009
SOURCE: Hp 3055 laserjet scanner problem
That scanner was not the greatest.
remove the glass and clean the bulb and mirrors.
This helped my problem.
frank
Posted on Jan 15, 2008
SOURCE: scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Posted on Jan 14, 2010
SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Posted on Aug 06, 2008
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Hp laserjet 3055 scanner error 6 turn off then on
You are going to have to have a tech replace the scanner assembly.
Jan 27, 2011 | HP LaserJet 3055 All-In-One Printer
Please give explanation & soulation hp laser jet 3055 scanner error 6 \r\nWhy this problem are create in our printer
Scanner error #6 = DocOriginFind
Per the service manual here are the steps:
1 - Power Cycle the Machine (I'm sure you've done this already)
2 - Replace the Scanner Assembly (After replacing this if the message still appears then.. )
3 - Replace the Formatter and Line Interface Unit (LIU)
Oct 20, 2010 | HP LaserJet 3055 All-In-One Printer
Laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
Hi sumittaneja0:
Try these steps.
52 Scanner Error The all-in-one has experienced an internal
hardware error.
1. Turn off the power by using the power
switch, and then wait at least 30
seconds.
2. If a surge protector is being used,
remove it. Plug the all-in-one directly
into the wall socket.
3. Check the FFC connection between the
formatter and the scanner.
NOTE Do not bend or fold the
FFCs during the removal or
reinstallation process.
4. Try connecting the product to a different
power source or surge protector.
5. Turn on the power and wait for the all-inone
to initialize.
6. If the error persists, replace the laser scanner assembly
Hope this helps
Jul 10, 2009 | HP LaserJet 3055 All-In-One Printer
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
Scanner error 6
most likely dust on the scanner optics causing scanner to be unable to go to home position. Solution would be to disassemble scanner assy and clean optics or replace scanner assembly.Note HP service manual says to replace scanner assy.
Dec 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
758 people viewed this question
Seeker5211
Seeker5211
