Question about Samsung Refrigerators
Samsung american style fridge freezer cooling is ok but the defrost does not switch off unless you switch off the supply
    Sergeant:
  • 239 Answers
The main control board would have to be bad
Posted on May 26, 2017
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
Samsung fridge not working freezer is?
sounds like you removed the defrost tstat.you need to replace it.if your evap coil ices up it will block the cold air flow to the frige section.replace your bad part so your defrost system willwork
Nov 27, 2012 | Samsung Refrigerators
Hi there- recently my samsung fridge began to make a bit of a knocking noise like the fan was dying down whenever I opened the fridge door. Now my fridge won't cool down below 58 degrees. From what I can...
It sounds like the defrost is not working properly and ice has built up inside where the fan is and the ice is restricting normal operation of the fan.Try fully defrosting over 24 hours if possible the defrost heater will still need investigating.
Hope this helps.
May 18, 2010 | Refrigerators
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
Apr 01, 2008 | Refrigerators
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
