My remote control is not working. I've changed the batteries and tried to re-pair it, but I can't get it to move anything.
shaggyrat
  • 1224 Answers
SOURCE: remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Posted on Jun 08, 2008
  • 5 Answers
SOURCE: remote control battery flat i changed the remote control batterie
sorry what message are you getting
Posted on Jul 13, 2009
K42282
  • 98 Answers
SOURCE: remote control has stopped working. Have tried
Does the red light on the remote light up when you push any of the button
if no, replace remote
if yes, then try repograming the remote to the car again.
-Have remotes' ready. if you have two then fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 8)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes' should work again.
good luck
Posted on Dec 17, 2010
caroldon
  • 17130 Answers
SOURCE: my remote control for bench
Please check the link below for help;
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on May 12, 2011
ginko
  • 19396 Answers
SOURCE: We have a 19" Polaroid flat screen TV along with a Polaroid remote control, which no longer works. The TV functions perfectly with the controls TV's built-in controls; however, the remote does nothin
Hi.
Please test the TV using a programmable remote. If the TV works using the programmable remote buy a replacement remote control:
NEW POLAROID REMOTE CONTROL TDA-03211C TDX-01930B
Polaroid TDX01930B Replacement Remote Control
Polaroid Remote Controls
Posted on Dec 09, 2011
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
My samsung 3D led multisystem smart TV remote control does not work anymore
  1. TV off
  4. Turn on TV
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote will not work
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Mar 05, 2014 | Samsung TV Remote Control
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
Changed batteries in remote now remote not working
Was your remote working before changing the new batteries?.
If yes, try another pair of batteries.
Nov 04, 2013 | Hunter 52" Ceiling Fan With Light And...
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
Can't pair up my blu-ray remote with the PS3.
I had same trouble in the beginning.
I have 80G PS3 and tried pairing and also registering.
I solved it by taking out the batteries then going to the menu where it says Register Blu Ray remote (System 2.40 version) then put the batteries back in and you do as the instruction says => Press Start and Enter button at the same time for 10 seconds ... it will say it registered.
I just did it.
Dec 29, 2008 | Sony Blu-ray Remote for PlayStation 3
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
