Question about Bell Televison & Video
Just purchase a used hd pvr 9241 can i install it on my bell dish do i need different switch
chamboard
  • 557 Answers
SOURCE: Do you have to have 2 coaxil jacks when connecting bell's hd pvr?
use scart are better !!!!
Posted on Aug 19, 2009
SOURCE: I have a Bell 9242
Sorry but tried all the codes above in Bell remote. Non of them work the fx900w.
Posted on Jan 23, 2010
  • 5 Answers
SOURCE: Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Posted on Mar 09, 2010
citroenchris
  • 600 Answers
SOURCE: i have two iomega 500gb
If it shows on the desktop, go to utilities then disk utility and repair disk, also check as it may need formatting for the windows FAT format.
Posted on Feb 10, 2011
  • 10 Answers
SOURCE: my new harmony 600 do
Do not bring your remote back to the store. Check on logitech's site for help. If it does not help send the remote back to logitech.
Posted on Mar 05, 2011
Bell satellite receiver model 9241 pvr function doesn't work
Hello, if you receiver is on rental I suggest to get a replacement from Bell it's free if it's still on warranty, otherwise here is what you should try, open the battery panel there are screw there you must take off, then slowly using a butter knife go around the remote to unsnap the two peace open, after it's open you need a Q-tip and some alcohol, dip the tip into alcohol and drip the extra of the q-tip with your two finger you don't wish too much alcohol, clean the inside of each button, it should look like little black round rubber, make sure to change your q-tip if it turn too dirty, after you clean all those button, gently clean the surface of the electronic part, don't use too much alcohol and don't push to ******* the electronic, you just need to take off the dirt and grease that might have accumulate there with time, let it dry few 1 min, then close and it should work like a new one, let me know :)
Jul 02, 2016 | Bell Televison & Video
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
How to connect a Logitech x-540 speaker system to sharp aquos LC-40e77un tv vIA A bELL 9241 hd RECEIVER
Yes, this is normal, but it should be just for the speakers, not for the receiver.
Nov 01, 2011 | Logitech X-540 Computer Speakers
My harmony 600 wont control my Bell 9241 PVR
Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
Feb 12, 2011 | Logitech Harmony 600 Remote Control
Cannot find code for universal remotes to make Sony DAV-C450 work
To repair your original remote, open the remote and remove the buttons sectio.(normally a solid piece of rubber with the buttons) On the PC board of the remote, clean with a scotchbrite scourer to revive the circuits and make it shiny. Next, clean the rubber button section on the inside with surgical spirits. Replace cover and fit new batteries.
Jul 12, 2010 | Sony DAV-C450 System
Good luck....
Mar 05, 2010 | Denon AVR-1908
Can you connect an archos 605 to a bell 9142 pvr
Archos Dish Network Plug-In says:
  •  Quickly transfer hours of your favorite TV programming from select DISH Network DVR receivers and enjoy the shows you watch every day- on the go.
  •  DISH Network customers with ViP622TM and ViP722 TM DVR receivers can enjoy this next generation of PocketDISH service with Archos 605 WiFi and Archos 705 WiFi models
  •  This plug-in is free for DISH Network Customers.
  •  Not a DISH Network customer? Find out more at www.dishnetwork.com and get the most out of your Archos player today
  • Jan 24, 2009 | Archos 605 WiFi Digital Media Player
    Televison & Video Logo
    44 people viewed this question
    Top Bell Televison & Video Experts
    ray gallant
    Are you a Bell Televison and Video Expert? Answer questions, earn points and help others
