Question about Refrigerators
Why does my icemaker dispense crushed ice on the cubed ice mode?
    New Friend:
  • 17 Answers
It sounds like the solenoid inside the freezer is stuck. Open the freezer door and remove the ice bucket. Looking at the bottom of the ice bucket you will see a thin metal arm sticking out the back. This thin metal arm activates whether your ice is crushes or cubed. With the ice bucket removed look at the back wall of the freezer and find the square hole where the thin metal arm goes into. Most of the time you can place your fnger inside the square hole and lift the plastic upward. If you are unable to lift it up you will need to replace the solenoid assembly.
Posted on May 04, 2017
    Top Expert:
  • Refrigerators Master
  • 78,267 Answers
It is defective.
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Our GE Monogram Icemaker will only dispense crushed ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Only will dispense crushed ice, no cubes.
Sounds like the piece which lifts up the crush/cube actuator behind the ice bucket . Will have to be replaced with 1 piece (plunger AND actuator ) .
Jul 18, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
MZD2666KES will no longer crush ice. The dispenser light is on however it dispenses cubes only.
Did you pull the icemaker out and then have the problem?
If so, select 'Crush' and Slide the ice maker out and slide back in. You will notice a rod on the end (bottom left of the unit) slides into a little cubicle that moves up and down to provide either crushed or cubed.
May 21, 2008 | Maytag Refrigerators
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
