SOURCE: do i get into my tablet trio if i don't know the password or my gmail account
you can make another account and use that.you can have as many gmail accounts as you want
SOURCE: sound problems on tablet
It sounds as though the switch on the phone jack is not making connection when the phones are unplugged. You can probably clean it by spraying some contact cleaner in the jack, then plug and unplug the phones several (lots of) times. I've had good success with WD40, but it does leave a residue. If this does not fix the problem, you can open the tablet by gently prying the screen off with thin blade (a knife might work). Work your way around the entire screen until the body separates. Gently open and perhaps you can access the jack switch to clean it, if it is not sealed. I hope this is helpful to you.
SOURCE: How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Every thing is low quality chines junk these days and probably head phone jack input is broken and it is not repairable as all similar items ,
As mentioned above, SoundAbout should work.
