How can I get audio to play it just switched to headphones and I cannot get any sound
    New Friend:
  • 10 Answers
Its would help if we had more information ie what machine have you got what OS is installed
if its windows 10 just right click the speaker bottom right hand corner then click open volume mixer, then click once on system sounds, under playback right click the one you want and set as default...
Posted on May 05, 2017
2 Suggested Answers
jovianstone
  • 7 Answers
SOURCE: headphone jack does not work, audio still plays from speakers
sound like the hardware supporting your headphones may have disconnected from its solder.This could have happened from dropping the notebook with the headphones plugged in and landing badly, or a strong or constant tug on the input. Otherwise, it could be a software configuration like you've tried
Posted on Jun 08, 2009
In a 2004 Lincoln Navigator if you play a DVD but hook headphones up for the sound can you play the radio at the same time
No. The radio uses the same circuits as the DVD audio to get sound to the speakers. The headphones only divert the audio from the speakers to the headphones.
Mar 13, 2017 | Lincoln Cars & Trucks
No sound from internal speakers after using headphones
The headphone jack has a switch in it to disable the speakers when the headphones are plugged in. This switch has stopped functionong. Look in the jack eith a magnafying glass to see if there may be lint or some other object holding the switch open when the headphones are not plugged in. Otherwise it's time to replace the jack.
Apr 19, 2014 | HP (153147-001) Sound Card
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
NO SOUND
First, check your tv's audio settings, somebody might be playing a prank on you. Next, try listening through the headphone jack, if it has one (after tv setting's ok). If sound is heard through the jack only, the audio jack might be defective, BUT highly unlikely if you hardly even use that headphone jack very oftenly. There are a couple more I'd like to say but will take up more space here. Using the remote control is one...i'm just suspecting these in order as my last resort...(switching) IC responsible for audio digital switching, or just plain ol' defective audio amp.
Oct 09, 2012 | Philips 52PFL7422D/37 TV
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
The sound on my firefox browser is low but when I listen to Window media player, it is very loud.
Try following solutions, if it works for you
To switch between speakers and headphones on Firefox,
make sure your headphones are plugged in first,
Right click on volume on the bottom right corner of your screen,
Then select Volume Mixer,
then double click on System sounds,
Click on the playback tab,
then you could switch between speakers or headphones, just select one and click "set default" and OK
only sounds in firefox will play in the headphones,
and windows media player will play on the speakers
You could leave your windows media player to play on the speakers while you listen to firefox videos in the headphones
If you want the media music player to play in your headphones also;
You have to change it in the media player program,
go to options on the media player, then look for playback devices, there should be 2 options speakers and headphones,
just pick one
I usually set the firefox audio to my headphones,
and a media player to the speakers
Please rate & vote if you like solution...
Thanks
Mar 13, 2011 | Computers & Internet
Brand new. No sound from any speakers or headphone. Headphone indicator is on without headphone jack inserted
try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
Nov 17, 2009 | Onkyo TX-SR876 Receiver
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
How do you get headphones to play back from the interface?The main headphone socket plays back but I casnt get any sound out of the headphone 2 socket.
Hi
More than likely not connected on motherboard as most of the cheaper board as only support one sound out.
Cheers cbacer
Aug 10, 2009 | Motu 2408 mk3 Digital Audio Interface...
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
