Question about Kidde 10-Year Smoke Alarm w/10-Year Battery, KID9000136
The smoke alarms are not tied from the upstairs to the downstairs. No way to get the wiring in
  • 42 Answers
Into what?
Here's a manual, maybe this can help you?
http://www.tlc-direct.co.uk/Technical/DataSheets/Kidde/ManAC%20Inst%20Kidde%201235-7223-10.pdf
Posted on Jul 25, 2009
How do I fix two three way switches where only one of them controls the light?
--------------- wire #1 ---------------------
power in --- -----power out to
--------------- wire #2 --------------------- light
the upstairs switch is improperly wired. With the breaker off, un wire the upstairs switch. Using an inductive tester with the breaker back on (use caution not to get shocked, determine which wires get power from the downstairs switch in EACH position (there is no 'off' in a three way). when you determine which two wires bring power to the upstairs switch, the remaining wire is the light.
Nov 29, 2014 | Electrical Supplies
My telephone connector is downstairs, and I want to have my PC upstairs - but I do not want to run wires around the house. Is there any way I can connect my computer wirelessly. i.e router downstairs,...
Yes, a wireless router should work fine.
You'll need a wireless-adapter (either internal PCI add-in card, or external USB stick) in your computer, if it does not have built-in wireless capability.
May 22, 2011 | Computers & Internet
My smoke/carbon monoxide detector keeps saying "low battery". I have replaced the batteries in all (5) detectors. They are hardwired. The one downstairs goes off continually and now the one...
My Smotec 3786A indicates not to install it in above 85% humidity.
One of my three seems to go off annually or so and this is what
recently put it down to. I was making an espresso coffee on the
stove and it generates a lot of steam and off goes the fire alarm.
I did change the battery to no avail.
Mar 28, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
Not enough heat
Take an Amp draw on all heaters and compare. If within 5%, they are working fine but you may have more open area downstairs than up.
Mar 03, 2010 | Heating & Cooling
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
My ac blows warm air upstairs only but not downstairs in winter
Sounds like you have a zone system? Is it a bypass type? If it is the fan speed of the heater must be to slow to override the bypass damper. Wire the fan to operate at a single speed same speed as on the A/C.
Jan 05, 2010 | Heating & Cooling
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
Jun 16, 2007 | Weather King 12AJA4801AH Air Conditioner
Kidde 10-Year Smoke Alarm w/10-Year Battery, KID9000136 Logo
179 people viewed this question
Top Kidde Home Experts
Tre Elkins
matt martin
matt martin
Are you a Kidde Home Expert? Answer questions, earn points and help others
