Question about Vtech Cell Phones
If I change bundling my VTech phone model 20-2431 carriers from direct tv to Comcast will I lose my stored messages that are stored with VTech. Not the carrier
betz73
  • 298 Answers
SOURCE: CECT P168
try this ...this will show you how.
please rate me as fixya.
watch the video it will walk you threw the whole thing.
it should work...although i have not done this so good luck.
Posted on Aug 16, 2008
SOURCE: i have an evenflo front
I had the same problem with our snugli serenade...
I used model number 0651767 mfg date jan 01 08. It found part number 25707046 that was a downloadable pdf.
May be a newer model but it seems the same as my 2005.
Hope that works.
Posted on Oct 24, 2008
damanpreet_c
  • 69 Answers
SOURCE: CLEAR THE CARRIER
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
SOURCE: Carrier Jam
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Posted on Mar 26, 2009
  • 906 Answers
SOURCE: lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Posted on Jul 30, 2010
How do i change the OG message on my vtech answering machine thru uverse?
Enter the model of your VTech system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Aug 16, 2014 | Vtech Lands Phones
How to retrieve Voice Mail from my Vtech 6. phone?
Enter the model of your VTech DECT 6.0 system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
To check your Comcast voicemail, see http://customer.comcast.com/help-and-support/phone/get-voicemail-while-traveling/
Dec 17, 2013 | Vtech Lands Phones
My landline is hook up to ciso an thats hook up to netgear how do i make calls out
If it's a cable modem you should have your phone landline connected to the cable model, if you have a "bundle". TV, Broadband, Phone with your provider. For example: I have Comcast/Xfinity bundle, TV, Phone, High Speed Internet. At the Comcast Modem it has a Phone jack RJ-11 for landline and Fax and a RJ-45 for my Wireless Access Point and Ethernet cable.
Jan 18, 2013 | NetGear WGR614 Wireless Router
I love my Vtech phone but much to my dismay, when I cleaned it I accidently deleted my message on the Answering machine part and can't locate the manual, yipes! Need to put another one on, please...
http://www.retrevo.com/samples/Vtech-manuals.html
This website listed above shows the manuals for the vtech phones. Find your model number on your phone and retrieve the manual from the site. On the part of recovering your deleted messages on your vtech phone, you can't recover them from the device itself. If you have Vonage, Comcast, AT&T or Verizon, which all have VoiceMail systems. They can recover your deleted messages. I hope something turns out for the good on this vtech problem.
Jul 20, 2011 | Cell Phones
I'm using an old digital cordless 900 phone and have Comcast answering service. How do I get rid of the Vtech built in answering service. I turn it off but it interferes and comes...
Since you declined to specify the model of your VTech phone, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download a copy of the manual and the instructions on changing the language.
Mar 16, 2011 | Vtech Lands Phones
Have a 900mhz cordless phone how do i change the message on answering machine
Since you declined to specify the model of your VTech system, I can only direct you to enter it into the search box here to download a copy of the manual.
Jan 25, 2011 | Vtech Lands Phones
I wish to change my answering message. Please advise.
Since you declined to specify the model of your VTech DECT 6.0 system, I can only direct you to enter the model into the search box at
Jan 22, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Lost my manual. How do I change my outgoing voicemail message (greeting)?
Dec 20, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I retrive my messages from my vtech 5.8. Also, how do I change the 2 digit code?
Since you declined to specify the model of your VTech system, I can only direct you to enter it into the search box here to download the manual.
Dec 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Comcast bundle
Contact comcast and let them know there is a problem with your phone signal. The problem sounds like it is on their end.
Apr 18, 2008 | Linksys Wireless-G Broadband Router
Cell Phones Logo
Top Vtech Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Vtech Cell Phone Expert? Answer questions, earn points and help others
