Question about Briggs Garden
My Briggs and Stratton mower was working fine 4 days ago, I put new premium gas into the machine today and it ran fine for 5 minutes then it conked out and will now not start at ball.
  • Briggs Master
  • 14,384 Answers
Never put premium gas in your mower,always use regular unleaded.Empty tank out,under the carb is a bowl,with a screw holding it on,remove screw and empty bowl,be careful and don't loose rubber washer,when you remove screw,gas will come out,put rags under bowl before you remove to catch gas,and always use lawnmower oil in the oil tank.Your spark plug may have fouled out,also replace it.You may need a socket to get screw off.
Posted on May 04, 2017
Riding mower wont start
if the carburettor is fine and the choke is working, check the ignition timing.
May 19, 2016 | Briggs & Stratton Briggs Stratton Intek V...
Gas and spark but will not run
try another spark plug. I have had good spark that would not run. changed plug anyway and ran fine
May 26, 2014 | Briggs & Stratton Garden
Engine is misfiring.
Put the old plugs back in. The new plugs my not be gapped correctly or one may be bad.
May 05, 2014 | Briggs AND Stratton Intek Briggs &...
17hp kohler ohv runs rough and muffler glows red hot
muffler full of carbon remove muffler heat up red hot throw in bucket of cold water remove and throw as hard as you can on pavement clean carbon out of exhaust part of headt make sure piston is all the way up you dont want carbon in your motor reinstall thank me
Oct 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
8 hp B&S amf dynamark rider ran it out of gas, since filled w/new gas starts but quits running after 3-5 mins
try and run it with the gas cap loose when you refueled it dirt might have blocked the vent on the cap
Jul 10, 2012 | Briggs & Stratton Briggs Stratton...
Lawn Boy 10641
see if the oil smells like gas the carb maybe sticking and gas gets into the oil washing the oil out this will make hard starting and smoke if so the needle valve is not sealing if you caught in time without major engine damage a sign is the oil being over full and smelling like gas
Apr 03, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Mower ran fine a couple days ago. Went to start
Remove the plug, pull the rope several times. Wait about 30 minutes. Put the plug back in. Try again.
Choke off? Use sparingly if at all. If you have a primer button, only press it 5 or 6 times.
Is your plug in good contition? It may need a replacement. Make sure you get the correct plug.
Let me know how this works out.
a
Sep 21, 2009 | Garden
Garden Logo
26 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
