Question about Refrigerators
I think i damaged something with the hairdryer while trying to thaw my water in the door
I have had a recurring problem with the tube that dispenses the water in the door freezing up. I usually unthaw it with the hair dryer. I wedged the hairdryer under the dispenser in the door and it looked like it may have overheated it. I was kind of stuck in place and when I pulled it forward, it doesnt work anymore. It doesnt seem like it's making contact with anything. I dont hear the click anymore like I used to, even when it was frozen. All of the lights work, such as cube, crushed, water, etc. Could I have overheated the solenoid?
    New Friend:
  • 17 Answers
An overheated solenoid will only affect the ice dispenser not the water section so we can rule that out. I would render a guess that the dispenser paddle is broken or melted. This would prevent the microswitch from making contact with the paddle. Replacing the paddle should fix the issue but you will have to verify.
I assume you have a GE fridge based on the frozen water line issue. Instead of heating the area with a hair dryer i have had great luck with this little trick. Purchase a container of "zoom spout oiler" which can be found on amazon. Empty the oil into a suitable container and flush the residual oil out with water. Next time it freezes fill the zoom spout oiler with hot water and extend the nozzle inside the frozen line and squeeze. I also disconnect the water line behind the kickplate under the freezer. Lock the dispenser so you don't accidentally pour water on your floor. Put a towel on the floor and when you clear the blockage at the dispenser water will flow onto the towel. Hope this helps you with your fridge!
Posted on May 05, 2017
Water,ice dispenser only dispenses ice
The switch in the door could be bad. the water side of the water valve could be bad. Sometimes especially in GE SXS refrigerators the water tube freezes in the door. You will have to see if you are getting water to the door by disconnecting the couple under the freezer side and tap the water dispenser if you get water there then the tube is frozen and you will have to thaw out the door for a couple hours. A slight possibility is the water reservoir in the fresh food section behind the crisper could be frozen. Again you will have to thaw it out.
Aug 15, 2014 | Refrigerators
Water supply isnt getting to the ice maker .
HI welcome to fix-ya. Sounds like bad watervalve with a frozen filltube. Try using a hairdryer to thaw the tube that the water enters icemaker. Then replace watervalve. I take it you can get water out of the door and the filter is ok. This can also cause the problem. I hope this helps.
Sep 08, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not getting any water from the dispenser, water supply is ok, I can hear a clicking when depressed but no water?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
May 15, 2011 | GE Refrigerators
LG refrigerator model #LRFD25850TT water dispenser no longer working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. Or use a hairdryer on the inside of the door below the dispenser.
Dec 26, 2010 | Microwave Ovens
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
Water dispenser is not working. Checked tubing and does not seem to be frozen. I heated the lines anyway with a hairdryer and left the freezer and the refrigerator door open for about 30 minutes. No...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Dec 15, 2009 | Washing Machines
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Hi. The water flow is very slight. I have changed the filter to no avail. I have well water and suspect that something might be clogged or there must be a pump someplace? The water flow into back thru the...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 04, 2009 | Refrigerators
No water going into door for dispensing or ice maker mod# MRS26LJ
I'm not sure what you damaged with heat but- Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 08, 2009 | Frigidaire FRS26H5AS Side by Side...
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
