Question about Symbol Office Equipment & Supplies
I am trying to find the symbol where there is a line drawn horizontal on the zero. please help me i am using a TI-83.
SOURCE: my ti-83 plus has OS problem
the buttons are *hold clear and take the battery out then put it in dont release clear until you turn on the device* OR * the same with the DEL button
Posted on Nov 21, 2007
  • 4 Answers
SOURCE: Texas Instruments Ti-83 Plus Help
possibly water damage... there might be an indicater of this such as one on a cell phone. behind the battery possibly, a small sticker that changes color when dampened.
as for solutions... warrenty? lol
Posted on Jan 31, 2008
  • 13 Answers
SOURCE: how to put square root symbol on ti-83 calculator
Press the 2nd button then the x-square button (4th button below the 2nd button).
Posted on Jun 28, 2009
  • 7993 Answers
SOURCE: When I turn on my TI-83 Plus I see my cursor along
Reset calculator
[2nd][MEM][7:Reset][1:All RAM][2:reset] then [CLEAR] the screen.
Hope it helps.
Posted on Sep 10, 2009
  • 7993 Answers
SOURCE: texas instruments ti-83 plus. only have black line on screen
Reset the calculators memory [2nd][MEM][7:Reset][1:All Ram][2:Reset]
If that does not work
You should reinstall the system which you find here
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and Click OK..
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
If all that does not work, then it may be time to head for a place of worship to pray for its resurection, or look for a repair shop.
Hope it helps
Posted on Sep 14, 2009
There are no grid lines when i push graph on my TI-83 Plus.
If you mean the axes, execute the AxesOn command from the catalog. Press 2nd [CATALOG], use the up/down arrows to get to the AxesOn line, press ENTER twice. If you still don't see the axes, check the window range (press WINDOW) to make sure the range includes zero.
Or do you want some other type of grid lines?
Feb 26, 2011 | Texas Instruments TI-83 Plus Calculator
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
How can i find a minute sign in my Ti 83
Press [2nd][APPS] to open the (ANGLE) menu. The symbol for the minutes is the second in the list. To enter the seconds press [ALPHA] [+].
When entering an angle in D(egree)M(inute)S(second), you must enter the number of minutes even if it is zero.
12 deg 25" will give a syntax error, so you have to type 12 deg 0' 25"
Apr 09, 2010 | Texas Instruments TI-83 Plus Calculator
My graph is not showing up when im typing an equation....the line will show and the points but not the graph....plzzz help!
Your graphic is drawn in dotted style. Change it to connected if you want.
Press [MODE] Use arrow to highlight Connected and press [ENTER]. Press [GRAPH] tor edraw your graph.
Hope it helps
Oct 27, 2009 | Texas Instruments TI-83 Plus Calculator
I was on my finance app on my ti 83 plus and touched a wrong button ( i'm not sure which) now my general screen has a weird display of p/y=1 and some horizontal lines. it has stopped giving answers. the...
I was able to reproduce the output p/y 1 but I have no isea what the horizontal lines come from. (maybe you set the split screen in mode Horizontal) but that would be touching more than one button.
Press [2nd][MEM][3: Clear Entries][ENTER]
or Press [2nd][MEM][7:Reset][1:All Ram][2:Reset]
In case you are interested, here is what you did to get the p/y =1.
You pressed [APPS][->>][VARS][6:P/Y][ENTER] to get 1.
Hope it helps.
Oct 24, 2009 | Texas Instruments TI-83 Plus Calculator
Random screen
I'd try reinstalling. Can you connect to the computer and use ti connective software. You can download everything from the ti web site. need more help to step you through it email me at: raklein62@yahoo.com
Aug 09, 2008 | Texas Instruments TI-83 Plus Calculator
Jan 31, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 LCD Screen Problem
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
Aug 14, 2007 | Texas Instruments TI-83 Plus Calculator
27 people viewed this question
Top Symbol Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
