Question about Sony Televison & Video
My Sony kds-60a2000 the power light comes on my bulb tryes to turn on two time then red lamp light kicks on... What's wrong
  • Sony Master
  • 10,291 Answers
The ballast control board has failed. This board is the one that the wires from the lamp is connected to. Replacement parts are here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on May 04, 2017
    Top Expert:
  • Sony Master
  • 79,865 Answers
Shorted circuit board.
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
ltfrc
  • 227 Answers
SOURCE: kds-50a2020 sony tv will not turn on
You may have luck in reading the blink code to find your problem at this link.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mike
Posted on Mar 22, 2009
protvrepair
  • 153 Answers
SOURCE: my power light is flashing red three times on and
The 3 blink code indicates that the lamp door is not secure. If you havent removed the door then its probably the switch for lamp door sensor.
I would remove the lamp door and then reinstall it. Do this with the set unplugged then plug it back in and check operation.. Basically sometimes the lamp door switches become dirty and by removing and reinstalling the door it usually corrects the problem..
If this doesnt work then you will need to either have the set checked out by a tv technician or you can try replacing the switch yourself. But as I said normally just removing and reinstalling corrects the problem.. Good Luck!
Posted on Nov 18, 2010
welcomejee
  • 10594 Answers
SOURCE: I HAVE A SONY KDS-60A2000
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
Posted on Mar 11, 2011
SD Tech
  • 14553 Answers
SOURCE: how to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Posted on Mar 01, 2012
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
POWER
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
easyab
May 06, 2011 | Sony KDS-60A2000 60" HDTV
I replaced the bulb on the kds-60A2000. Now the red LED power light is blinking 3 times. I know that indicates the lamp door may not be securely attached. I have replaced the bulb before and had no...
The tv know the door isnt on because of an internal switch. Make sure all doors are on usually three blinks indicates door isnt on. If the tv still doesnt power on your balast might be out.
Mar 25, 2011 | Sony KDS-60A2000 60" HDTV
I HAVE A SONY KDS-60A2000 WONT TURN ON. RED LIGHT BLINKS THREE TIMES. TRIED NEW BULB. NO DIFFERENCE
Thanks.
Mar 11, 2011 | Sony KDS-60A2000 60" HDTV
Picture on my sony kds 60a2000 tv goes out and then comes back on repeatedly, what could be wrong
you have to replace the bulb what happening is the life hours on the bulb is almost over just replace the bulb soon or later you will see a red flashing light sometimes that's indicating the bulb needs to be replaced
Jan 26, 2011 | Sony KDS-60A2000 60" HDTV
hope this helped
please rate well
Mar 04, 2009 | Sony KDS-60A2000 60" HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
