Question about Refrigerators
My fisher,paykel fridge freezer keeps defrosting ,refreezing ,how can I fix problem,keeps leaving a puddle at the bottom of the fridge
  • 1462 Answers
SOURCE: We have a fisher and
not the seals. the drain is blocked. take the rear panel off inside the freezer and yoy will probably see an ice build up at the bottom. melt off with a hairdryer and follow up with hot water till water flows away freely. if you have ice build up all over the pipework, then you have a defrost system fault and get back to me
Posted on Jul 18, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
woodchuck789
  • 4070 Answers
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 28, 2009
  • 5 Answers
SOURCE: How do I defrost the freezer of my Fisher Paykel
its easy, just open the freezer door
Posted on Feb 17, 2010
Water leaking bottom of crisper.
You may just have to manually defrost it.
Dec 16, 2014 | Fisher Refrigerators
I have a Fisher & Paykel model C370 fridge which is constantly icing up at the bottom of the rear condenser panel, causing puddles in bottom of fridge and on floor.
Sounds like either your defroster heater motor or your defrost timer has gone bad. Generally not user serviceable. Call an appliance repairman and have them fix it for you.
Feb 16, 2013 | Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
Oct 04, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
