Question about Refrigerators
My fisher,paykel freezer keeps defrosting ,leaving a puddle
  • 833 Answers
SOURCE: Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
Posted on Dec 04, 2007
22yooper
  • 828 Answers
SOURCE: my upside down fridge freezer
Beeping noise can be caused by door being ajar. Check product storage and make sure something is not preventing your door from fully closing.
Posted on Apr 29, 2008
  • 677 Answers
SOURCE: Fisher & Paykel leaves film
the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Posted on Aug 22, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
woodchuck789
  • 4070 Answers
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 28, 2009
Fisher and paykel n405l fridge freezer .Freezer on top is working but fridge not working
There is a problem in the defrost system. Could be the defrost timer, defrost heater, or defrost safety thermostat.
Jul 14, 2014 | Fisher and Paykel Refrigerators
Fisher Paykel E521T
Here is a video which may help you, there are also useful comments
Apr 13, 2014 | Fisher and Paykel Refrigerators
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
Oct 04, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
How do you manually start timer on fisher paykel
We disconnected the refrigerator and took the back of the freezer apart. There we noticed ice had built up on the coils. After removing all the food, we let the freezer defrost for 3.5 hours. Then we connected it, and it started to cool down immediately. After 1 1/2 to 2 hours, the refrigerator was down below 40 degrees. All food was replaced, and now the refrigerator is working properly All of this was down to the Fisher Paykel Model E522BRM.
Aug 31, 2009 | Fisher and Paykel Active Smart E522B...
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
bec,
Dec 03, 2007 | Freezers
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
