Sound I have a lc60le835u purchased 12/29/11 the sound now comes like we are in a barrel and cannot get it out. Any sugestion to correct?
I cannot get sound when connect sharp sound Bar HT-SL50 to a Sharp LC60LE835U
You have to go into the sound setup menu and select which audio out you are using. Select either digital or fiber so the TV can direst the sound to the proper port.
Jul 08, 2014 | Sharp LC60LE835U 3D LCD TV
The left earbud of my new headphones wont work
Che k the end of ur headphone jack also check where its being put into possibly to rule out its not faulty headphones i sugest try them on something else then u can rule that out
Oct 28, 2017 | Sony Audio Players & Recorders
1997 Blazer, had key in forward position and battery gauge was good and dash lights on. Relays on firewall got moved and lost all power. How do I restore?
I would sugest the problem lies with the ignition switch or barrel if you can't move the key. I would 1st remove the switch from the barrel & turn with screwdriver to see if it operates.
Jun 24, 2012 | 1997 Chevrolet Blazer
I have a winchester 1000 and when i break the barrel it shoots
sounds like there is an obstruction between the barrel and the firing chamber.try cleaning the barrel and the chamber. If this does not work make sure when you place the barrel in the firing position that everything is lining up correctly allowing for an efficient release of air from the chamber.
Oct 13, 2010 | Daisy Winchester 1000B Synthetic Stock...
Whats causing a metal clanking sound from my
could it be the catylitic convertor you're talking about???
May 20, 2010 | 2000 Yamaha YZF-R1
Piston shot to 3 pieces cylinder damaged,hadnt been fitted properly by previous owner 15yr old needs help doing enduro on sat
buddy its not an easy job to do as if the barrel has been damaged that much it will have to rebored to an over size piston or a new sleeve installed or if its just a little scratch you can get some glass paper and run it around the barrel not stying in 1 place at the same time do this until smooth also you can take it to a shop and get them to rehone it for you or rebore it also when you put the new one in oil the rings and make sure the arrow is pointing towards the exhaust valve
Sep 10, 2009 | 2002 Yamaha YZ 426 F
AIR CONDITION
Just tell me if you have a single unit or a split unit,I can help you with this problem,but need to know what you have..
Waiting for your youre reply.
Sep 10, 2008 | Heating & Cooling
Menu Problem
Just obtained means just purchased from a normal seller[shop]? Take more time with the manual until you are certain that the device is not functioning as it should - then return to the seller as faulty Sometimes it is easy to miss something- especially with these new touch screen systems Do come back We are all learning here
Aug 21, 2006 | Sony Cyber-shot DSC-N1 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
