Question about Vizio Televison & Video
Got 48 inch Vizio tv hooked up last night fine . turned on this am fine then roommate sd had horiz. lines. turn it off back on works briefly. need help
  • 148 Answers
SOURCE: ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
Posted on Dec 28, 2007
  • 280 Answers
SOURCE: My Vizio vp322 will not power on this morning
Probably the power supply has gone bad.. This happens with no warning. Sometimes it is just bad capacitors that have leaked or puffed up in the power board and a good tech can do a cheap fix by replacing them.. Other wise the PS board has to be replaced
Posted on Feb 20, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 8546 Answers
SOURCE: STR-DE475 receiver flashes "PROTECT" when turned on
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Posted on Apr 02, 2009
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Apr 25, 2014 - Uploaded by
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Dec 15, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
The volume on the TV doesn't work. TV worked fine last night
You can always turn your TV off, unplug it from the electrical outlet, wait for 30 seconds or so, plug it back in, then turn it back on. If you have kids check the menu options to see if they may have tampered with it unintentionally. If all else fails, call Vizio and ask for their professional help. If you are not satisfied with their help and assistance, make a complaint by going to (Better Business Bureau). Maybe if you tell Vizio that you're going to call the BBB then they might take you a little more seriously.
Aug 28, 2009 | Vizio L32 32 in. LCD HDTV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Player won't turn on
Loud noise = diode is bad, and the dvd player needs to be repaired/replaced
Jun 16, 2007 | Toshiba SD-K740 DVD Player
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
