Question about Mitsubishi Televison & Video
I have a Mitsubishi 57732 remote not responding & front panels not working properly. I do get a picture just no sound. Do I need to replace Ir sensor.
  • 192 Answers
SOURCE: Mitsubishi WS65411. Front panel dead.
 This set has a keyboard lock feature and it can be removed by pushing in the menu button on the front keyboard on the set for about10 seconds. This should take care of your problem.
 Reply to this post if you have any questions and I will respond.
Posted on Oct 14, 2007
  • 56 Answers
SOURCE: Remote sensor in the TV
Remote sensor is locketed on pcb it an be replaced
Posted on Aug 23, 2009
SOURCE: How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Posted on Nov 11, 2009
SOURCE: unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Posted on Dec 12, 2009
SOURCE: cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Posted on Jan 22, 2010
REPLACING IR SENSOR
You have to open the TV and take out the front panel PWB out from it to replace the infrared sensor. This is somewhat skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Televison & Video
I need the exact location of the IR sensor on the front panel of a Motorola DCH6416 cable box.
Do this like mine sweeping. Grab the remote and put it right up to the front of the box. Press the channel up or down keys as you move the remote across the front of the box. You'll get to a point where the box responds well. Then as you go past the point the box will stop reacting so well. Home in to the point where the box responds well. That's your point for the blaster.
Sep 14, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
Remote problem
check the remote by looking at it through a digital camera while pressing a button on the remote if the light is visible in the camera then the remote is working and the IR sensor board will need replacement you can get replacement IR boards and the remote from www.tvrepairworld.com
Jan 02, 2013 | Televison & Video
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
LG 32LD320-ZA remote sensor
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
Jun 13, 2012 | LG 32LD320 32 HDTVReady LCD TV
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
Cable box remote doesn't work when tv is turned on.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dead lamp
The sensor is located on or near the lamp compartment on the back side. If your lamp keeps blowing it may be the lamp cooling fan not working. However are you sure the lamp is blowing? Press menu and device on the front control panel both in together for 5 seconds and see if the led blinks a two digit code, then let me know the code. Please respond to this same post.
Jul 08, 2008 | Mitsubishi WD-57732 Projection Television
Remote will not function with TV
If two remotes do not work. I would say the IR sensor on the front panel of the TV might be defective.
Can you provide an exact TV model number to try to locate an IR sensor part suppier?
Mar 10, 2008 | Toshiba 36A43 36" TV
Open Questions:
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
