Question about Celestion Audio Players & Recorders
Celestion csw subwoofer, Speaker relay does not close. When putting a spkr on input of speaker relay there is sound, Relay driver transistor has .6 volts on the base, but only 15 volts on collector..
4 Suggested Answers
  • 75025 Answers
SOURCE: the 130 volts relay is
If the all said voltages are there and still the relay doesn't work check the transistor drive it and the relay itsef. Relays will have the voltage and its coil resistance marked on it. Check it coil resistance and be sure it comes to the marked Ohms. If has the proper Ohm resistance, check the transitor drives the relay for open [usually collector to emitter]. If the transistor used there is a PNP type, coltage at its base should be low, and if its an NPN type the voltage should be high inorder to drive the relay.
Check whether the base voltage of the said transistr varies, that is going up and down, during the power on and off switch on the remote control If there is no volgage change, the voltage remains constant all the time, check the power on off voltage chage at the respective pin in the system control Ic. If there is voltage changes and there is no voltage changes in the transitor said. means there are some trouble between the path, and check whether other drive transistors are used in between them. If so check it too. Ok.
Posted on Oct 27, 2010
  • 4234 Answers
SOURCE: No signal through main amp
If the speaker relay does not activate, then the amp is in protect mode. There is a problem in that has been detected in the final stage of the amp. You indicate that you have 4V at the power transistors. That is likely the B+ voltage. What is the reading at the other 2 pins? Please post that and I should be able to give you some ideas.
Posted on Feb 22, 2010
Testimonial: "Many Thanks Dan"
  • 2850 Answers
SOURCE: a voltage drop from 12 to 6 volt or find the cuase of it
I'd start by checking ground connections. How are you checking voltage at the relay? Across the coil, or coil to ground? Coil to ground is important to check.
Posted on Oct 23, 2015
How do I set up a Celestion S10 Subwoofer...
Voltage is relevant to where you live in the world. America it's 110. Europe mostly 220.
What you're asking is a very deep and complicated question.
I'm attaching a link with some articles.
What I suggest is that you find an upper end audio store and ask a 20 audio head to set up your system for you. Subwoofer Setup and Calibration for Best Bass
Apr 12, 2014 | Celestion S10 Subwoofer
No sound on ch2 of output speaker
Switch rca inputs (may be the input wires), also switch speakers(maybe a bad spkr)... if neither works you prob have damage in the input stage of the amp...
Apr 16, 2013 | Audio Players & Recorders
Harman Kardon AVR 7500 Does not power up and can't find fuses!!!
Honestly, if you are talking about the speaker protection relay, the relay and associated circuits rarely go bad but instead respond to problems elsewhere in the amp. Anything from defective speakers, bad spkr. wiring to output transistors will cause this protection relay to not energize thus protecting the output stages and speakers.
Feb 20, 2013 | Audio Players & Recorders
No sound from Celestion F20 subwoofer. Tweeter is OK, and so is the other speaker in the pair. Wiring OK as switched speakers around to test.
Since these can be bi-amped or bi-wired (and you don't indicate if that is the case) you need to make sure the jumpers are secure (see the last picture or (if the jumpers are removed) that you have viable amplifier signals coming to each speaker within the cabinet.
May 30, 2011 | Celestion F20 Main / Stereo Speaker
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
I have a Celestion CSW Sub woofer. It powers on as the light lights up but I get no sound i checked the fuse and it seems to be great and intact. I also checked the actual driver to see if it was blown or...
This speaker has a low frequency roll-off filter. Does your program source have low enough frequencies to pass through the filter? The effect of the subwoofer on most music is very subtle unless there is heavy bass in the source. You should try some songs that have a heavy under beat.
How are you driving the CSW -- by way of the line input or as a series connection to your full range speakers?
Jul 13, 2010 | Celestion CSW Speaker
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
How to run wires is series fof 3 subs
If they are single voice coil speakers (1 positive and 1 negative terminal on each speaker) then connect from amps' Positive output terminal to spkr. 1 positive terminal, THEN spkr. 1 neg. terminal to spkr. 2 positive terminal, THEN spkr. 2 negative terminal to spkr. 3 positive terminal, THEN spkr. 3 negative terminal to amps' negative output terminal.
That is 3 speakers wired in series. if each spkr is 2ohms, then you will have a total 6 ohm load. If 4 ohm spkrs., then a total 12 ohm load, if 8 ohm spkr., then a total 24 ohm load.
Be careful because amps do not like these odd ohm load totals. You might get away with a 6 ohm total load. Depends on the amp.
Mar 27, 2010 | Jl Audio 10W6v2 Car Subwoofer
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
43 people viewed this question
Top Celestion Audio Players & Recorders Experts
Robert Rankin
Richard Lindsey ...
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
