SOURCE: about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
try to setup again wireless card's driver if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
SOURCE: Wi-Fi
Press and hold fn and at the same time press the f2 button which has a wifi or 2 screens logo with a signal picture to sswitch wifi on.When it detects a wifi signal or says wifi detected just click the message and using your login and password connect to your network name.
SOURCE: i have problem with the wi-fi network adapter.its
If it is a F500, it is a common fault with the series. The manufacturers warranty was increased to 2 years, and the wifi is covered. The motherboard will need to be replaced, so give HP a ring, or contact the store that you bought it from, and they should be able to help.
