Question about Refrigerators
My fridge is telling me the door is open but clearly it's not
  • Refrigerators Master
  • 9,845 Answers
Replace the door switch.
Posted on May 04, 2017
Opening fridge door and it beeps
perhaps the reed switch (the magnetic switch to tell the PCB the door is open/closed).
With F&P fridges, the amount of beeps will indicate the error code which relates to which component is faulty.
Sep 14, 2016 | Fisher and Paykel Active Smart E522B...
Fridge light won't turn off..does that mean the fridge has stopped working or only the light needs to be fixed? Can tell it's not cooling as much as it used to.
The light is usually a seperate circuit to the fridge compressor and it staying on is more likely to be a faulty switch than the fridge not working. Open the door and look around the perifery of the door opening, there should be a spring loaded plastic part that pushes in when the door is shut and springs out as you open the door. Try manually pushing it in and see if the light goes off, if it doesn't then the switch behind it may have become dilogded in it's housing or broken. Turn off the power to the fridge, unscrew the housing, re-position the switch or replace it, re-fit the housingturn on the power and test.
Jul 02, 2013 | Frigidaire Refrigerators
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
How to unstop drain
If there's a drain, a shop vac will clear it. If no drain, you're getting too much condensation inside the fridge. Check the door fit, make sure no one is leaving the door open too long. If your freezer is overflowing into the fridge, a manual defrost may clear the problem. That takes a long time, have somewhere else for your food.
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Samsung RS20....noticed this AM the fridge side in not cold enough and the temp number on the door is flashing on and off.
Sounds like you're frosting up.
Defrost unit manually. Clean the condenser coils. Don't leave liquids uncovered. Don't leave the door open unnecessarily. Make sure all air passages are open and clear. If this doesn't fix it long term...you likely have lost some refrigerant and need a recharge.
Jun 08, 2008 | Refrigerators
SIDE BY SIDE FRIGIDAIRE REFRIGERATORS
Freezer door switch that tells the fridge that the door is closed might not be in contact with the door when it is closed. Safety mechanisms make it such that the water will not dispense if the fridge thinks the door is open.
Mar 07, 2008 | Refrigerators
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
