Question about Car Audio & Video
The center headlamps in my Ford Fusion 2006 wont turn off even when the keys are already in the ignition and all the doors are closed can some help fast thanx
  • 82 Answers
Take out the bulb before your battery dies, then check the dome light switch for a short, also the door switches
Posted on Jul 25, 2009
When I turn the ignition off the average fuel reading returns to zero,all other readings,tripometer,miles to empty remain.
2006 Ford Fusion Owners Manual - Scribd
https://www.scribd.com/doc/.../2006-Ford-Fusion-Owners-Manual
Mar 10, 2014 - 2006 Ford Fusion Owners Manual - Ebook download as PDF File (.pdf), Text ... To reset the switch, refer to the Fuel pump shut-off switch in the .... Holding the TRIP/RESET button for two seconds or more will reset the trip odometer to zero. .....Turn the ignition switch to RUN and then back to LOCK. rotate the ...
[PDF]Ford Fusion - Dealer e-Process
cdn.dealereprocess.com/cdn/servicemanuals/ford/2006-fusion.pdf
2006 Fusion (fsn) ... well acquainted with your vehicle by reading this handbook. ...Fuel pump shut-off switch: In the event of an accident the ..... reset the trip odometer tozero. ..... Turn the ignition switch to RUN and then back to LOCK. 4.
Nov 24, 2015 | 2006 Ford Fusion
Key stuck in ignition in park. Check charging system comes on. Dealership says it might be a fuse.
Key Stuck in Ford Fusion (2006 model) - YouTube
? 1:21
https://www.youtube.com/watch?v=3LVQttFOzGA
Jun 18, 2014 - Uploaded by Jessica East
#Ford #Fusion #Key #ignition #Stuck #FordFusion2006. ... i have a 2006 mercury milan and my key got stuck in there last night,... it to park with a little bit of force. will see what happens next time. good video, nice to know.
Key Stuck in Ignition While in Park
www.2carpros.com/.../2007-ford-fusion-key-stuck-ignition-while-park
Dec 16, 2012 - KEY STUCK IN IGNITION / SHIFTER BINDING CONDITION FORD:2006-2007 Fusion LINCOLN: 2006 Zephyr MERCURY: 2006-2007 Milan
Nov 06, 2015 | 2006 Mercury Milan
Where's headlight relay @ on a 2010 ford fusion 2.5
There is no relay for low beams , the ( SJB) smart junction box , a control module an fuse / relay center in one.
When the SJB receives an input requesting the headlamps on, the SJB supplies voltage to the low beam and high beam bulbs as necessary.
The smart junction box (SJB) monitors the headlamp switch position by sending voltage reference signals on multiple circuits to the headlamp switch. At any given time, one of the signal circuits is routed to ground. If the SJB does not detect any of the inputs to the headlamp switch is active (routed to ground) for 5 seconds, the SJB turns on the exterior lights and keeps them on for 10 minutes after the ignition switch is turned off (or 10 minutes from the time the SJB does not detect any headlamp switch input if the ignition switch was already off). If the SJB detects multiple circuits short to ground, the SJB implements a planned strategy depending on the multiple inputs received. If either of these situations occur, the SJB should NOT be ruled immediately as being at fault. This is normal behavior of the SJB design as it has detected a fault with the inputs from the headlamp switch.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Multifunction switch
  • Headlamp assembly
  • Battery junction box (BJB) fuse(s):
    • 19 (40A) (low beams)
    • 26 (15A) (LH high intensity discharge [HID] headlamp)
    • 27 (15A) (RH HID headlamp)
  • Smart junction box (SJB) fuse 11 (15A) (high beams)
  • Ballast
  • SJB
  • Bulb(s)
  • Circuitry
Jun 20, 2015 | Ford Cars & Trucks
7 dings and a beep when starting 2000 ford explorer? what does that mean
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with a scan tool.
There are five warning chimes and lamps the GEM/CTM controls: headlamps operating without the ignition on (chime only), door ajar (chime and lamp), key-in-ignition (chime only), driver seat belt warning (chime and lamp), and message center.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition - Continuous Chime, 120/Min. 740 Hz Headlamps On - Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) - 1 Second Single Tone, 1000 Hz
When the is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
The will turn on for 60 seconds or until the driver safety belt is fastened. Both the chime and the lamp turn on at the same time.
If the safety belt is buckled before the ignition switch is turned to RUN or START, from OFF or ACC, neither the chime nor lamp will be activated.
Anytime the is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed or the safety belt is buckled.
When at least one door is ajar and the key is in the RUN position, the door ajar cluster lamp is activated and remains on until all doors are closed. A warning tone will sound once any time the key is in the ignition switch and any door is open.
The key-in-ignition warning will sound when the driver side is opened with the key in the and the in OFF or ACC. It will continue to sound until the key is removed, the is closed, or the is in RUN or START.
The headlamp-on reminder chime will be activated if the headlamps or parking lamps are on, the key is not in the ignition switch, and the driver door is opened.
A single tone will be provided each time a ground signal is received from the message center. A one-second tone will sound for warning indications from the message center. A 100 milli-second tone will sound for each message center button depressed.
Feb 12, 2015 | 2000 Ford Explorer Eddie Bauer
How to overide limp mode in 2006 ford fusion
put the key in the ignition, and turn it so the lights and everything come on, do not start the engine, then pump the brakes 3 times, turn it off, and then start the engine. This worked for my 2008 for fusion. (if the brakes don't work, try the gas 3 times make sure the engine is off and the car is in park)
Best of luck!
Mar 01, 2011 | 2006 Ford Fusion
After I've turned off my car. Removed the key from my ignition. Locked my door. The inside light located in the ceiling of the car still won't go out. Why? How can I make it go out?
Wait until your door closes all the way and then press the lock button. My Fusion does that too but after I get out of the car, shut the door, and lock it the light goes out.
Jan 02, 2011 | 2008 Ford Fusion
Can you tell me where the emergency shut off switch is on the 05 ford fusion 1.4 petrol please? had a small tip last night and the engine wont fire.
Its in your owner manual, or go to motorcraft.com, pro center, tech info, owner manual and look it up.
FUEL PUMP SHUT-OFF SWITCH
This device stops the electric fuel pump from sending fuel to the engine
when your vehicle has had a substantial jolt.
After an accident, if the engine cranks but does not start, this switch
may have been activated.
The fuel pump shut-off switch is
located in the front passenger
footwell area in the right upper
corner.
To reset the switch:
1. Turn the ignition to 1 (LOCK).
2. Check the fuel system for leaks.
3. If no leaks are apparent, reset the
switch by pushing in on the reset
button.
4. Turn the ignition to 3 (RUN).
5. Wait a few seconds and return
the key to 1 (LOCK).
6. Make another check for leaks.
2006 Fusion
Dec 27, 2010 | 2005 Ford Fusion
My 2006 Ford Fusion's radio won't turn off. Everytime I take the keys out and open the door the radio doesn't cut off!! Why!!!
U have a defective door ajar switch most likely, if this switch remains closed then the delayed exit feature stays on, this means the radio will stay on because the delayed exit module didn't sense the door was opened, try opening the passenger door to confirm this problem, any door should turn off the radio
Mar 11, 2010 | 2006 Ford Fusion
Possible ignition switch problem? 99 Explorer
key chime sounds if the little tab is grounded where the key contacts it. The theft light is supposed to blink when the system is armed to let you know it is armed. That's normal.
What do you mean by auto door locks won't unlock? The remote doesn't work? the door lock/unlock button on the door trim panel? Do they lock ok? Or, just unlock doesn't work?
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with New Generation STAR (NGS) Tester.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition — Continuous Chime, 120/Min. 740 Hz Headlamps On — Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) — 1 Second Single Tone, 1000 Hz
  1. NOTE: The generic electronic module (GEM)/central timer module (CTM) must be reconfigured upon replacement. Refer to the New Generation STAR (NGS) Tester help screen on the configuration card to program the Tire Size, Axle Ratio.
    The power windows system and rear window defroster system are (GEM) controlled systems.
  • All Windows Operate With the Ignition in the OFF Position
  • Circuitry.
  • Accessory delay relay.
  • CHECK the accessory delay relay; REFER to Component Test. If OK, REPAIR circuit 400 (LB/BK). If not OK, REPLACE the accessory delay relay. TEST the system for normal operation.
report back
May 06, 2009 | 1999 Ford Explorer
Key on engine running trouble code 55
Warning Chime Systems The generic electronic module (GEM) will sound the following warnings:
  • key-in-ignition warning
  • safety belt warning
  • headlamp switch ON warning
  • door ajar warning
Headlamp Switch On Warning The generic electronic module (GEM) sounds when the driver door is opened while the headlamp switch (11654) is in the PARK or HEAD position, and continues to sound at a rate of 4 chimes per second until the headlamp switch is turned off or the driver door is closed.
  • When the headlamp switch is in the PARK or HEAD position, power is supplied through Circuit 293 (O/R) to the GEM.
  • When the driver door is open, the driver door open warning lamp switch (10B997)is closed and ground is supplied to the generic electronic module (GEM).
A delayed headlamps on repetitive chime will sound for a period of three seconds beginning twenty seconds after the key is turned to OFF, LOCK or ACC, the headlamp switch is in the PARK or HEAD position, and the driver door is closed. Delayed headlamps on is terminated by opening and closing the driver door again.
Door/Liftgate Ajar Warning The door/liftgate ajar warning functions as follows:
  • The generic electronic module (GEM) sounds a warning tone for one second when any vehicle door, liftgate window or the liftgate is ajar without any other door already open and the ignition switch is in the RUN position.
  • Power is then supplied through Circuit 627 (BK/O) to the door ajar warning indicator lamp which remains illuminated until all doors are closed or the ignition switch is no longer in the RUN position.
Key-in-Ignition Warning The generic electronic module (GEM) sounds when the LH front door is opened with the key in the ignition switch and continues to sound until the key is removed or the door is closed.
  • When the key is in the ignition switch, the ignition key warning switch terminal and wire (11A128) is closed and ground is supplied through Circuit 158 (BK/PK) to the generic electronic module (GEM).
  • When the LH front door is open, the LH front door open warning lamp switch (10B997) closes and ground is supplied through Circuit 57 (BK) to the generic electronic module (GEM).
Safety Belt Warning When the ignition switch is turned to RUN or START from the OFF or ACC position and remains in RUN or START, the chime will sound for six seconds or until the safety belt is buckled. The safety belt warning indicator lamp (10C859) will turn on for 60 seconds, or until the LH front safety belt is fastened. Both the chime and lamp activate at the same time. If the safety belt is buckled when the ignition key is turned to RUN or START from OFF or ACC, the lamp will prove out for two seconds, but chime will not be activated. Any time the key is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Feb 25, 2009 | 1999 Ford Taurus
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
