Hook up for wireless fit tontv - Computers & Internet
How do I connect wireless headphones to a Dynex 42"TV model DX-42E250A12?
Check this link for a user manual
http://www.dynexproducts.com/cms/documents/Manuals/DX-42E250A12_11-0618_MAN_V1_EN_Final%20lr.pdf
Sep 07, 2014 | Dynex Televison & Video
Tip
How to hook up a wireless router.
<ol> <li> <p>Open the wireless router box and examine the contents. You should have the router, a setup CD-ROM, a network cable and a power adapter. If any of these are missing call the company on the box.Put the setup CD in the<a href="http://www.ehow.com/computers/">computer</a>. A screen will come up and ask you if you want to start the setup. All this CD is doing is taking you step by step through the hook-up process. Click Start setup.Choose which language you want to <a href="http://www.ehow.com/how_4424109_hook-up-wireless-router.html#">continue</a> in from a drop down menu and click next.Go over the user license agreement and check the box that says, "I accept this agreement." When you are ready click next.Allow the program time to check your <a href="http://www.ehow.com/internet/">internet</a> connection. When it is done it will say, "Check successful." Click next and you will be ready to begin hooking up your new wireless router.Remove <a href="http://www.ehow.com/internet/">the internet</a> cable from your computer. It will be the only one that goes in to a phone jack. Then plug it in to the wireless router in to the yellow spot. Each spot is colored for your convenience, but it should also be the only spot that fits the plug so you can't get it wrong even if you try. When you have done that click next.Get the network cable you found in your box. The cable should be blue. Plug one end of the cable in to the blue spot of your wireless router and the other end in to your computer. It will only fit in one spot so don't worry. Click next when you are done this part.Plug the power adapter into the wireless router. It goes right next to the blue wire, and will only fit in that one spot. The other end should be plugged in to an outlet or power strip. Click next and wait for the system to check if the router is hooked-up properly. If it is hooked-up properly it will say, "Configuration Complete." Click next.Click next to close the setup wizard and begin using the new wireless router. This process should have only taken you a total of five minutes. If you have any problems contact the company listed in your instruction booklet.<br /></li> <li> <p><br /></li></ol>
on Dec 05, 2010 | Computers & Internet
Trying to hook up wireless internet to desktop
the first thing you will need to do is get a wireless card for your desktop. you can pick one up at best buy. after that all you need to do is open your computer and put the card into any slot that it can easily fit into (do not force) and after that it will be as easy as waiting for the drivers to install and choosing your network
Nov 05, 2011 | Dell Computers & Internet
Can I hook up other speakers instead of the orginal ones
yes you certainly can. If the speakers fit the jack, then you can use any speakers. You can even use a wireless transmitter and even hook it up to a stereo system.
Aug 12, 2010 | Logitech Z-5300 Computer Speakers
How do i hook my printer up and start useing it
If your computer has a woireless network card fitted. It is a matter of following the instructions in the printer manual to have it discovered by the network. Some PRINTERS USE AN IP # like 192.0.0.0 and a subnet mask of 255.0.0.0 which is local to your network.
I am not sure about this lexmark model But if your PC has wireless it will find it the minute its turned on and bind.
Thanks for using FIXYA
Apr 12, 2010 | Lexmark X4690 Wireless InkJet Printer
How can i get my internet to work on my labtop with no ethernet ?
You can purchase a usb Ethernet adapter that plugs into the side of your laptop. You could buy a wireless card that could fit into your computers card slot.
If you mean that you don't have Ethernet in your home you could go wireless and use whatever free access you might find. Check out an electronics store for improvised attachments. Many types are available.
Feb 19, 2010 | Compaq Computers & Internet
How do i hook my xbox up to my computer to get on xbox live?
hi,
just to elaborate on zombies post.....
Zombie is correct in what she says...but in 'Laymans' terms.........
you dont need to hook up your xbox to ur computer to get 'On Live' .
The easiest way is a direct 'Ethernet' lead (plugged into the back of ur 360....(dont worry....u cant put it in the wrong slot....an ethernet lead will only fit an ethernet slot)) & the other end into an empty Ethernet slot on your broadband suppliers router (the little box they sent you which is plugged into ur fone line)....there are usually '4' ethernet slots on most routers ! once the ethernet lead is plugged in just follow on screen instructions (xbox) for 'signing' up to 'Xbox Live' :-)
hope this is a little easier to understand ??
p.s. Dont get ripped off buying an ethernet lead if u havnt got one long enuf ! dont let the shops tell you ur better off with 'Gold' plated ones !! its rubbish !! u dont need gold plated !
the usual 'bay' shop (u know who i mean??) have numerous suppliers....u dont want to be paying more than £5 for at least a 5 metre one !
p.p.s dont bother with the wireless adapters !! there pants !
good luck :-)
Feb 13, 2010 | Microsoft Xbox 360 Console
Trying to hook verizon UM150 card to verizon wireless DSL Gateway
the UM150 wireless card goes into the computer.
however, the DSL need to be wired to your computer for initial configuration.
if you just hook up the DSL as verizon say, then you will have a open wireless network, anybody can get access to your network.
Feb 03, 2009 | Verizon Communications Ethernet/Wireless-G...
When wireless switch is flipped on Toshiba laptop Satellite A105-S2716 - the screen goes black and blinks repeatedly. I thought my screen was going bad but as soon as I flip the wireless switch to 'off'...
this could be a connection problem with the wireless antenna, which is interfering with the monitor, as most laptops have a high effeciency antenna which is fitted in the screen surround, so i would send to a qualified repairer to check it out.
Sep 24, 2008 | Computers & Internet
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
