Question about JVC Car Audio & Video
JVC KS-FX240 Car audio system CD player stopped working. No response when CD button pressed, remains on radio. The Cd player has been working well, now only the Tape player works or the radio function button that switches between stations.
simplemitch
  • 752 Answers
SOURCE: CD Player not playing any audio CDs
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
Posted on Sep 12, 2007
SOURCE: cd player opens when turned on and will not function
I have brought my system to a JVC service center in January. They kept it for 2 months, trying to find the problem.... Finally, they told me that they would need to replace the whole CD player section (drawers + reader assembly). The cost of this repair would be more than the cost of a new system !!! I now have a large, expensive RADIO TUNER in my bedroom, without CD player :-(. I hope someone will find a solution. This is the last JVC system I purchase, EVER.
Posted on Apr 17, 2008
  • 1861 Answers
SOURCE: CD player does not work
If you are using home-made, or "Burnt" CDs, this is the root of the problem. Toyota Cd players are sometimes not compatible with the abovementioned CD's. Also, if the CD is scratched badly on the bottom side closest to the "hole", the info that the CD reads to "know" that the CD is physically IN the drive may be compromised.
Posted on Sep 08, 2008
SOURCE: JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Posted on Feb 01, 2009
  • 59 Answers
SOURCE: 6-Disc CD Changer is not working
Unfortunately most times with these 6-disc systems once it quits working it is usually time for a new unit. The manufacturers all reccomend reprogramming the radio, but this rarely does anything other than waste your time and money. Go for the new radio.
Posted on Mar 15, 2009
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
How do I reset the time on my JVC KD-R200 CD RECEIVER/ WMA MP3 PLAYER?
I am not sure about the reset. You can change time. Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Feb 09, 2015 | JVC KD-R200 Car CD/ MP3 Player
JVC KD-G801 CD player has light on (on) button but doesnt switch on when pressed
Look for a pinhole button on the face, just left of the #1 radio preset. Use a ball point pen or paper clip to lightly hold this button for 2-3 seconds. You may do this with the key on. This will reset the radio's microprocessor.
Let me know if this helps.
Dec 18, 2013 | JVC KD-G801 CD Player
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
Is the JVC CH -X400 compatible with the KS-FX222E?
Hello
The devices you specified here; JVC-CH-X400 and JVC KS-FX222E are non-compactable.
May 26, 2011 | JVC CH-X400 12-Disc CD Changer
Ipod not working on a JVC KD331 cd/radio car player
Check your stereo for a button that says "Aux" or a "Function" button. It could also say something else depending on the radio. The one in my 93' Mustang says "Band" and in my truck it simply says "iPod" Just mess around a little bit and see what you find.
Apr 11, 2010 | Car Audio & Video
RESET 2 compact disc charger CH-X350 JVC.
I have no solution but the same problem and wish to solve it asap.
Anyone would you please help
If anyone has a JVC 12 cd's changer CH-X350 and also had the same problem (radio says when you wish to hear cd's : Reset 2), would you please tell.
thanks.
Mar 13, 2009 | JVC CH-X350RF 12 CD Changer
KD-LX100 working fine, then CD sound stopped working.
That particular cd might have been damaged .
Have you tried with any other cd .
Nov 27, 2008 | JVC KD-LX100 CD Player
I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Jun 11, 2008 | JVC KD-G320 CD Player
JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
Sep 08, 2007 | JVC KD-G110 CD Player
Car Audio & Video Logo
127 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
