How do I hook wireless fit to t.v. - Computers & Internet
How do I connect wireless headphones to a Dynex 42"TV model DX-42E250A12?
Check this link for a user manual
http://www.dynexproducts.com/cms/documents/Manuals/DX-42E250A12_11-0618_MAN_V1_EN_Final%20lr.pdf
Sep 07, 2014 | Dynex Televison & Video
Tip
How to hook up a wireless router.
<ol> <li> <p>Open the wireless router box and examine the contents. You should have the router, a setup CD-ROM, a network cable and a power adapter. If any of these are missing call the company on the box.Put the setup CD in the<a href="http://www.ehow.com/computers/">computer</a>. A screen will come up and ask you if you want to start the setup. All this CD is doing is taking you step by step through the hook-up process. Click Start setup.Choose which language you want to <a href="http://www.ehow.com/how_4424109_hook-up-wireless-router.html#">continue</a> in from a drop down menu and click next.Go over the user license agreement and check the box that says, "I accept this agreement." When you are ready click next.Allow the program time to check your <a href="http://www.ehow.com/internet/">internet</a> connection. When it is done it will say, "Check successful." Click next and you will be ready to begin hooking up your new wireless router.Remove <a href="http://www.ehow.com/internet/">the internet</a> cable from your computer. It will be the only one that goes in to a phone jack. Then plug it in to the wireless router in to the yellow spot. Each spot is colored for your convenience, but it should also be the only spot that fits the plug so you can't get it wrong even if you try. When you have done that click next.Get the network cable you found in your box. The cable should be blue. Plug one end of the cable in to the blue spot of your wireless router and the other end in to your computer. It will only fit in one spot so don't worry. Click next when you are done this part.Plug the power adapter into the wireless router. It goes right next to the blue wire, and will only fit in that one spot. The other end should be plugged in to an outlet or power strip. Click next and wait for the system to check if the router is hooked-up properly. If it is hooked-up properly it will say, "Configuration Complete." Click next.Click next to close the setup wizard and begin using the new wireless router. This process should have only taken you a total of five minutes. If you have any problems contact the company listed in your instruction booklet.<br /></li> <li> <p><br /></li></ol>
on Dec 05, 2010 | Computers & Internet
Trying to hook up wireless internet to desktop
the first thing you will need to do is get a wireless card for your desktop. you can pick one up at best buy. after that all you need to do is open your computer and put the card into any slot that it can easily fit into (do not force) and after that it will be as easy as waiting for the drivers to install and choosing your network
Nov 05, 2011 | Dell Computers & Internet
Does the cateyeenduro2have a component that hooks onto the spokes and is it a speedometer
Yes to both.
Instructions:
http://www.cateye.co.jp/global_site/pdf/qsm/rd300w_qsm_w_v1.pdf
Functions:
Current Speed
Maximum Speed
Average Speed
Odometer
Trip Distance
Elapsed Time
Clock
Specifications
Fits almost any handlebar or stem: 22-31.8 mm
Fits almost any fork: 11-55mm
Batteries: CR2032 x 2 (1 each for head unit and sensor)
Front fork speed sensor
Feb 09, 2011 | Cateye Fitness Cateye Strada Wireless Bike...
How do you hook up the wireless router
First configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Then save settings and restart router. Then connect internet cable from service provider to your router's WAN port.If you want wired internet then connect lan cable from computer to router's lan port. Let me know if you need further assistance. Thanks for using FixYa.
Oct 16, 2010 | Computers & Internet
Can I hook up other speakers instead of the orginal ones
yes you certainly can. If the speakers fit the jack, then you can use any speakers. You can even use a wireless transmitter and even hook it up to a stereo system.
Aug 12, 2010 | Logitech Z-5300 Computer Speakers
How do i hook my printer up and start useing it
If your computer has a woireless network card fitted. It is a matter of following the instructions in the printer manual to have it discovered by the network. Some PRINTERS USE AN IP # like 192.0.0.0 and a subnet mask of 255.0.0.0 which is local to your network.
I am not sure about this lexmark model But if your PC has wireless it will find it the minute its turned on and bind.
Thanks for using FIXYA
Apr 12, 2010 | Lexmark X4690 Wireless InkJet Printer
I cant get the router hooked up.
Sounds like your PC does not have a PCI Network card. You can purchase one from NewEgg for <$20, or for a little more your local Walmart/BestBuy etc will have them.
Example of what you are looking for:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2052810027+1128209687+1162810711&QksAutoSuggestion=&Configurator=&Subcategory=27&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Once purchased they are easy to install.
Jun 16, 2009 | Linksys WRT160N Wireless Router
When wireless switch is flipped on Toshiba laptop Satellite A105-S2716 - the screen goes black and blinks repeatedly. I thought my screen was going bad but as soon as I flip the wireless switch to 'off'...
this could be a connection problem with the wireless antenna, which is interfering with the monitor, as most laptops have a high effeciency antenna which is fitted in the screen surround, so i would send to a qualified repairer to check it out.
Sep 24, 2008 | Computers & Internet
Hampton Bay Carriage House II
I went ahead and hooked up the wires, and then zip stripped the wireless receiver to the side of the motor mount. Works fine and fits inside the canopy (motor cover).
May 30, 2008 | Hampton Bay 13087 70450 Carousel II...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
