Question about Irons
How do you know when a maestro 70 iron has enough water when filling
  • 10,028 Answers
Water will no longer enter the fill port when it's full.
Posted on May 04, 2017
My iron keeps gushing water out of the steam holes
If you have over-filled it, or it's not hot enough, then water will come out the bottom. Make sure that the temp is in the "steam" range, and you give it a few minutes to warm up.
Oct 06, 2015 | Irons
How do I know when my IR4500SC iron has enough water as it is filled sitting flat?
Fill then stand it up to view the fill level. Unless you see a warning I doubt you can overfill it. Just top off the tank and go.
Nov 10, 2014 | Irons
Hi floyd, a friend of nime gave me a steamer and i dont know how to work it i dont know see where you put the water in at.i need to know step by step instrutions on how to work it.
what brand? what does it look like? should be a heavy screw-on cap on water tank. Fill with soft or distilled water, power on, and should be a red light that comes on when hot enough for steam
May 14, 2012 | Rowenta Commercial Garment Steamer - White
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
Where the heck do you fill the iron with water???
Usually there is a fill hole on the front of the iron. Place the iron in the upright position. Pour water directly into the hole and see the water level in the tank rise. Since I don't know which model you have, I can only give you generic instructions.
Aug 21, 2009 | Irons
Water in iron box
Yes... you can use it dry...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
Aug 15, 2008 | Panasonic Cordless Steam Iron - White/Aqua
Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Aug 04, 2008 | Rowenta Perfect Iron
How to use steam iron
Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
Feb 23, 2008 | Micro Pro 7599 Iron
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Irons Logo
69 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
