Question about Sewing Machines
Why does feeding dogs not working - Sewing Machines
  • Sewing Machines Expert
  • 455 Answers
Rinda what make and model machine do you have?
Posted on May 04, 2017
Janome 109/110 which hasn't been well looked after!Cleaned, oiled etc and sewing fine now but feed dog lever won't move to drop dogs for FMQ. Any suggestions? Thank you
Most likely the feed dog mechanism was not lubed enough to overcome the old oil that has turned to glue. It is very common for mechanical machines not well maintained over years to have the feed dogs seize. Use liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Get access to the area around the feed dogs (either from underneath if it is a flat-bed machine or via the free arm). Gently wiggle the handwheel and watch where the feed dog mechanism moves. Apply a couple drops every place that metal rubs on metal. Move the feed-dog drop lever and apply a couple drops where metal parts rub there too. Direct hot air from a handheld hairdryer into the internal mechanism, focusing on the feed dogs and the feed dog lever. You may need to alternate the lube and hot air several times until it begins to move freely. Repeat until things move well.
I've used this method on several older machines and it has always worked, although some machines take more work and time than others.
Oct 19, 2016 | Janome Sewing Machines
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
Feed Dogs
when the feed dogs are in the up position the sewing machine
will sew
but when the feed dogs are down postion it will darn
try the feed dog lever again if you can move the feed dog lever and
the feed dogs respond going up and down then you know that
the feed dogs are working and are not broke
but if they do not respond then they need to be checked to see what's
wrong with them
Oct 23, 2012 | Sewing Machines
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
